Old 03-29-2013, 10:29 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
i'm not sure which "brain" is doing the thinking for the fog light, just that it is fickle.
Old 03-29-2013, 10:31 PM   #2
None. There is just the switch, fog light relay, and if you have DRLs, the DRL relay is in circuit as well.
Old 04-01-2013, 11:01 AM   #3
Golddeenoh
Golddeenoh's Avatar
this appears to have been the problem it wasn't making a good connection in it and kept wiggling lose. I also moved my ground to better location the other one was questionable. now to see if it keeps working or starts being fickle again.
LF: Yaris switches carrera2 Willing to Buy by private party 0 07-11-2009 05:10 AM
Power Window Switches Stoln Australia 5 11-07-2008 09:02 AM
