Old 04-14-2007, 07:22 AM   #19
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
engine: very small roughness on metal surface, will whip off in the first 1-2 hundred miles
oxygen sensor (sets the fuel/air mixture, therefore affects acceleration and fuel consumption): when new, it needs to get "burned" in order to operate to the specs. The hotter it gets, the faster it burns. I'd suggest, passing the first hundred miles, start shifting/keeping the revs higher than usually (above 4000rpm) and drive so 2-3 gas tanks.
don't switch to synthetics before 1000 miles, a new engine needs to run on mineral oil
hystria is offline   Reply With Quote
Old 04-14-2007, 10:29 AM   #20
BMGYaris
Drives: Yaris 3dr Hatchback
Hey guys, this is just a theoretical situation. Its not like I did it or anything.
But what if someone got their car with say, less than 15 miles on it. drove it slowly home for 15 miles.
Then drove a 100 mile road trip in going some 110-120 the whole way, just because it was the first time he/she could. What kind of problems might he/she need to go get checked for at the shop?
BMGYaris is offline   Reply With Quote
Old 04-14-2007, 12:09 PM   #21
rage2
Drives: 07 Black Yaris 5D
My Yaris is my 5th new car. I've broken in all my cars by driving them hard straight off the lot. My Yaris has 115 hard km's on it, WOT to redline in every gear. The reason I do this is because cars that go thru a hard break in period will be more powerful than a "normal" break in. All 3 of my SLK's were broken in this way, and was faster than the others at track days. I've never had any problems with engine reliability either.
rage2
My Yaris Diary - All about my new Yaris!
My Blog - F1 News, Hotties, and Random Crap
My Site - Beyond Car Forums
rage2 is offline   Reply With Quote
Old 04-14-2007, 04:45 PM   #22
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
well, I agree for the first few thousand miles you should baby it and vary the RPM range, most of the breaking in is done at the factory these days, but you can never be to carefull...also, if you plan on shifting at higher rpms and flogging your car, keep in mind part of the break in process is seating the valves, and if the valves seat for the 3k-5k range and you constantly shift your yaris at 6k, its harder on the valvetrain and you wont get as much performance from the engine. I have not verified that on a newer car, but thats how they break in older muscle cars...I think the best way is to drive the car how you intend to drive it, but avoiding keeping it at the same RPM range for long trips (switching from 4th to 5th every now and then to vary the rpms).
Old 04-14-2007, 10:05 PM   #23
hystria
hystria's Avatar
an engine is an engine. sure, they say baby it the first hundred miles, try doing city driving instead of highway... at one point it helps, but how much ? statistically saying, maybe that engine would run 2% better that others...
if that is not a matter, drive it as you like from the very first mile. it's my advice as a mechanical engineer, two things seems to be important: use mineral oil for the first thousands miles and never rev high a cold engine.
rage2: what you are saying is all about the oxygen sensor, the hotter it gets the faster it starts work at his normal range
Old 04-15-2007, 11:15 AM   #24
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I really never gave the car a break-in since they come already tested from the factory. I just droved it hard a couple of times. I just think my engine came with the expected 106hp since we know hp factory numbers are estimated.
I Drive a 129whp Yaris ;)
Old 04-15-2007, 01:28 PM   #25
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
i drive it like i stole it, hehehe
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 04-15-2007, 01:32 PM   #26
rage2
No, I'm not talking about a cold engine vs a warm engine, I'm talking about 2 identical engines, one broken in "easy", and one broken in "hard", or drive it like you stole it. The engine broken in hard will be more powerful.
rage2
Old 04-15-2007, 01:38 PM   #27
ChinoCharles
Drives: LB
I peeled out of the lot when I bought it if that tells you anything. Couldn't help it! My dealership loves me anyway.
Old 04-15-2007, 06:16 PM   #28
Black Yaris
der Zeck
Black Yaris's Avatar
Drive it like it's hot... Wow, Chino actually changed his avatar!!!!
Old 04-15-2007, 07:02 PM   #29
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
I worried about the break in period as well. I drove mine as prescribed in the manual, varying speeds for the first 1,000 miles. I changed to Mobil 1 at 2,000 and follow factory intervals of 5,000. Now at nearly 15,000 miles, I've never burned any oil and get great gas mileage.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 04-16-2007, 03:38 PM   #30
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
ive been doing the same thing as well. my del sol was quicker then most and im hoping the yaris will be broken in just as good......
Old 04-16-2007, 06:04 PM   #31
rage2
yep, it's a nice little secret that some of us solo1 and solo2 guys use when buying a new car for the track.
The only time I run a easy break-in procedure on a car is when I'm building a new motor from scratch, for about 100km, to ensure the rings and walls are contacting smoothly. After that is an oil flush, then hard break-in!
rage2
Old 04-16-2007, 06:17 PM   #32
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
When I test drove a yaris it only had like 30 miles (I went home with it that night) I left the lot and waited till I came to the first stop and then let her loose, I chirped the tired shifting into second and beat the hell out of the car for about 15 minutes. Currently have 11,000 miles on car and no problems.
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 04-24-2007, 10:11 PM   #33
meteorite2007liftback
Drives: 2007 Meteorite Liftback Manual
I broke mine in with a combination of long highway trips and red line WOT shifting in between. Currently have just over 3200 miles and the oil level hasn't ever gone down a drop, which indicates rings are well seated and the break in was a success :) I think people (myself included) stress needlessly about the break in. Just think how many cars are out there that people buy new and aren't even aware of the term "break in" and drive their cars for hundreds of thousands of miles.
meteorite2007liftback is offline   Reply With Quote
Old 04-30-2007, 01:58 PM   #34
jlift
Drives: 2007 Yaris Hatch
Well, why then do some new cars come from the factory with Mobil 1 synthetic in them? I don't think that statement is accurate at all.
jlift is offline   Reply With Quote
Old 06-08-2007, 01:06 AM   #35
V8TITAN
V8TITAN's Avatar
Drives: 07 nissan titan, 07 yaris
honestly with such low horespower i didnt even consider going easy on it...plus with a nice warrenty how can you go wrong ? we never keep our vehicles past 30k tops...so none the worry.. i got my titan with 7 miles on it and i go WOT everytime...my tires dont like it but theyve gotta earn their keep lol that also helps out my 10mpg average haha
2007 TITAN SE fram boost intake, or,bt,cc,rf and other cool gismos.. sisters 2007 toyota yaris, bone stock..
[IMG]http://i8
V8TITAN is offline   Reply With Quote
Old 09-08-2007, 11:08 PM   #36
Ferret_san
Hack.... What hack ??
Ferret_san's Avatar
Drives: 07 YR
I peeled out of the lot when I bought it if that tells you anything. Couldn't help it!.
Now thats funny!
Ferret_san is offline   Reply With Quote
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
