#19 |
There isn't a torque measurement for a belt, but rather a deflection and a tension measurement. They point to check is half way between the alternator and the crank pulley.
Deflection: New belt 7.0 to 8.5 mm (0.28 to 0.33 in) Used belt 11 to 13 mm (0.43 to 0.51 in) Tension: New belt 539 to 637 N (55 to 65 kg, 121 to 143 ld) Used belt 245 to 392 N (25 to 40 kg, 55 to 88 ld)
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
when i had a loose belt it sounded like there was a pig being slaughtered under my hood. so idk, that doesn't sound so much like a loose belt to me. then again if CT says it does maybe you should listen to him.
![]() I crush you like tiny clown car, because you are clown, yes? |
#21 | |
#22 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
I assume you have already checked to make sure that the belt isn't bottoming out in the groves on the pulleys, that there is not any debris in the pulley groves, and that the pulleys are aligned?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#23 |
My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
nope. haven't popped the hood at all. been too busy and it's cold.
figured I'd ask if this was normal before I started poking around. I used to be under a car 5 days a week swapping trannys, replacing front ends, etc... but these days I am not a big fan of doing work myself anymore, lol. |
#24 |
hey guys, sorry it took me so long to reply to this topic, I've just been busy.
here is a wav file of the sound, about halfway through the idle drops and you can hear it even better. keep in mind that this was taken with the hood closed standing next to the car, not with the recorder in the engine bay. think it may be time for a new belt or at least a retension on this one? It doesn't do it when I first crank up in the morning but starts 2-3 minutes later (I'm guessing as the belt heats up it expands). Does the Yaris have automatic tensioners or is it something adjustable? Thanks. FILE http://www.filedropper.com/beltnoise |
#25 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
i had a bad squeal initially. new belt fixed that. now...after about 10,000miles or so...it does a tiny squeak on start up. I looked at the belt, its looks worse then it should for its age. im going to tighten it up a tiny bit more the next time i get a chance.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#26 |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I've been having this same noise. It only happens when I drive the car for a while, and it doesn't happen when you first start the car up.
#27 |
^exactly, and it's annoying as hell.
#28 |
Just listen to the wav file I attached in an earlier post.
#29 |
Only Happy When it Rains
the file in the earlier post is not normal. the filedropper link just goes to the main page, not to a file i can use.
i'd agree with CTScott. I have a full nst pulley set, and after tightening all the belts, i have zero extra noise that sounds anything like that. There is a chance the belt might be too tight as well, but that is a belt noise of some type.
Colin Chapman disciple |
#30 |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
still having issues with the pulley?
#31 |
![]() ![]() ![]() Drives: 2010 5 Door Join Date: Feb 2011
@captainslow I'm having the same exact noise after the MI pulley and its driving me INSANE. Did you find a fix?
lol okay |
#32 |
25, 550 MILES!
| pulling the AC belt pulley on front of compressor | yaris9876 | DIY / Maintenance / Service | 6 | 07-19-2012 10:12 PM |
| Squeaky belt after pulley install? | Black_griffin6 | DIY / Maintenance / Service | 12 | 07-01-2012 10:17 AM |
| Belt noise? | Cutie Pie #2 | DIY / Maintenance / Service | 20 | 05-22-2009 01:51 PM |
| Water pump belt and pulley - replaced at 36,000mi | cleong | DIY / Maintenance / Service | 3 | 03-06-2009 12:12 AM |
| Underdrive Pulley Belt | ruimond | Performance Modifications | 11 | 02-14-2009 09:05 AM |
