Old 03-21-2014, 10:32 AM   #19
Originally Posted by Bluevitz-rs View Post
I'm thinking, if there's corrosion or a loose connector on the feedback wire to the alternator regulator, it might be reading the voltage as being too low and making the alternator put out maximum output.
I'd have to look at how the regulator works again in my EWD.
The white wire on the alternator connector is the feedback wire to the voltage regulator. There should be battery voltage on that pin with the engine not running.
Old 03-23-2014, 02:50 AM   #20
Miryai
Drives: 2008 Toyota Yaris HB
I purchased a volt meter. It was $5 including shipping and handling, and you never know, it might be useful for one of my house mate's cars later. But once I have it, I'm gonna plug it in and run, see if I can manage to look at it when the issue is happening. But all I know, is that it's starting to occur a lot more frequently. It's happening more and staying on longer, than when it looks like everything is fine.
Miryai is offline   Reply With Quote
Old 03-30-2014, 02:28 AM   #21
Miryai
Since, I hate when no one updates their problem. Voltmeter came in today. My car idles at the high 13's to low 14's. That doesn't seem to be too bad, but when the battery light comes on, it skyrockets to at least 17. I think the highest I saw was 18.3, but according to my mechanics the alternator is fine (I doubt it.). Taking it to the mechanic on Monday and telling them, and seeing if they fix it....if not, I guess I declare my car a lemon since I've replaced this damn thing four separate times already.
Old 03-30-2014, 06:55 AM   #22
Now that you have the meter, with the engine off, check the voltage on the white pin of the alternator connector.
Old 03-30-2014, 07:15 AM   #23
For what it's worth, wiggle that connector first too and see if that fixes the problem. Also after you unplug it, have a look inside for any green corrosion. There's also a chance the pin isn't tight enough.
Sent from my iPod Touch
Old 04-29-2014, 09:29 PM   #24
nortonfb
Drives: 2007
Another return of an old thread.
My 07 hb has the battery light on.
My output is 13.5-13.8 with the fan, brights, emergency flashers, radio
and defroster. The battery is 12.8V.
The battery indicator does flicker every 5-7 seconds.
Battery is new as of 1/14.
I cleaned the ground & ground on the inner fender.
Also cleaned the positive connection.
The humidity here is high and is raining & will be until Sunday.
The car was purchased 2/14 and I have no history.
The dealer did do an inspection in February.
Ideas/thoughts?
Steve
nortonfb is offline   Reply With Quote
Old 04-29-2014, 09:35 PM   #25
Ideas/thoughts?
Steve
Sounds like the battery and alternator OK. Since the light is on constant, check the connector with the small wires, on the alternator to make sure it is plugged in.
Old 05-01-2014, 09:40 AM   #26
nortonfb
Drives: 2007
I removed all the connectors and cleaned.
Where I work they have a tester
The results are:
Battery V 12.72, 618cca, rating 575cca
Starter test 11.25v
Charging test v 13.94
I still have a glowing bright red battery light, I feel so cheap..
I'm hoping that this maybe humidity related & once we dry out it will go away.
Steve
Old 05-01-2014, 10:35 AM   #27
The results are:
Starter test 11.25v
Steve
Your getting good readings. Is your alternator the original one or a replacement?
Old 05-01-2014, 06:52 PM   #28
nortonfb
Drives: 2007
The alternator is marked Toyota Denso. I don't know if it's
original. I bought the car last February after I totaled my 08'.
Steve
Old 05-01-2014, 09:05 PM   #29
Steve
What's the part number on it?
There is a TSB on 07-08 alternators where the internals of the voltage regulator, within the alternator, corrode.
Old 05-02-2014, 10:58 AM   #30
nortonfb
Drives: 2007
The numbers are:
17060-21150
10 42 10 - 8180
12v / (1?) 6 6
MN
Toyota Denso
Thanks
Steve
Old 05-02-2014, 11:20 AM   #31
The numbers are:
17060-21150
10 42 10 - 8180
12v / (1?) 6 6
MN
Toyota Denso
Thanks
Steve
That first number should be a 2, instead of a 1 (27060-21150), but the 21150 versus 21151 is the one which potentially has the non-sealed voltage regulator, which is prone to corrosion.
Old 05-02-2014, 06:23 PM   #32
nortonfb
Drives: 2007
If there is a TB on it, does Toyota share any cost or they
are just aware a problem exits?
Thanks much,
Steve
Old 05-02-2014, 10:05 PM   #33
Thanks much,
Steve
With a TB they are not required to do anything, particularly if you are out of warranty. The TBs are really just references for techs on common issues.
Old 05-02-2014, 10:33 PM   #34
Is there really anything that can be cleaned or is it the IC itself that corrodes?
Old 05-02-2014, 10:39 PM   #35
It's a potted module. There are a couple of holes in the "bad" version and if it is bad you actually see rust at the holes. If you catch it before that you can simply seal the holes with a dab of RTV, but once corroded it is done, since you can't pull the module apart without damaging it.
Old 05-03-2014, 07:35 AM   #36
nortonfb
Drives: 2007
Is there specs on belt tension? I mat at some pointe change it out.
Looks like a bear. I cannot see the bottom bolts, no room.
Also there is one plastic connector I cannot figure out how to remove it.
I read here some where that Bosch is not as good a Denso, I can get Bosch but not
Denso, locally.
Any truth about Bosch?
Thanks
Steve,
DIM battery light 2o6 DIY / Maintenance / Service 9 11-22-2012 06:58 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
