Old 02-10-2013, 07:19 AM   #19
Originally Posted by petefozzy View Post
Hi could you please confirm wether this connection is C15 please before I go buy a diffrent speedometer thanks. The other one on top is for thr tripometer.
That is correct - C15 is the 22 pin one on the bottom left.
Old 02-10-2013, 10:08 AM   #20
petefozzy
Thanks for confirming that
petefozzy is offline   Reply With Quote
Old 02-20-2014, 12:46 PM   #21
zedmano
Drives: Toyota Yaris
Hi I am having same problem on 06 yaris display let me know how u get on
zedmano is offline   Reply With Quote
Old 02-20-2014, 12:54 PM   #22
petefozzy
HI I got another speedo from a breakers and all seems ok
Old 02-28-2014, 07:49 AM   #23
zedmano
Does the surround to the speedo just pull off having a little problem taking off?
Old 02-28-2014, 08:02 AM   #24
Yes.
Old 03-04-2014, 09:25 PM   #25
highlander
Drives: 1999 1.0 gls 5dr
I have had this same problem twice now, the first time i removed the electric ribbon that went to the speedo and replaced it with a second hand one which looked like new thinking it would last a few years but a couple of montha later the same thing happened again!
The speedo went off but the indicators kept working, the worst thing was the fuel gauge didnt work so even though i could use my phones gps to tell me my speed i just wasnt sure how much fuel i had left so i replaced the ribbon again and now it works fine but i dont know how long it will last.
I blame condensation in the car for this problem as it has happened in winter.
Replacing the filter behind the glovebox may help with condensation.
I might try wrapping it in tape and laquering to make it waterproof.
Anyway if you have the same symptoms try replacing the ribbon first!
highlander is offline   Reply With Quote
Old 12-05-2018, 11:18 AM   #26
smeeb2000
Drives: toyota yaris mk1 1.3 sol
had exactly the same issue everyone is talking about.
sent the entire unit off to an electronics place...they fixed it and it worked for 3 years ish.....but now its back again :(
smeeb2000 is offline   Reply With Quote
