Old 03-13-2013, 11:55 AM   #19
atxsteve1
Drives: THE RED HATCHY
Yeah they drop close to 2 inches front and back and are pretty comfortable ride.
I was running 18x7.5s 45mm offset with 215/35/18s lol and those springs with no rub.
atxsteve1 is offline   Reply With Quote
Old 03-13-2013, 10:42 PM   #20
Yarflana
Drives: 2008 Base Model
DF210s are the bomb!
Just installed the DF210s on the rear tonight (doing fronts Saturday) and boy are they perfect! I look forward to the fronts and I think I will be done.
Thanks for the help on the forum and from the Micro Image guys as well.
Attached a photo of the rear clearance, which is about none from the top of the tire to the top of the outer fender, although it looks like there is clearance on the outside.
Yarflana is offline   Reply With Quote
Old 03-13-2013, 10:45 PM   #21
Yarflana
I noticed on the rears that the DF210s are lighter than the Eibach pros significantly, almost by half! That is a good advantage as well.
I think the DF210's are a bit firmer than the Teins, and the Teins go just a bit lower and are a little softer. More or less comparable, really. That's been my experience after a few installs.
Old 03-13-2013, 11:10 PM   #22
atxsteve1
Lookin good. It's supposed no be a nice day on Saturday too.
Old 03-14-2013, 01:00 AM   #23
yariseggvvti
Drives: Yaris Hatchieback
I believe you just spent about less than hour to get the rear done. About an another inch drop looks better. Just about half an inch above the tire is good. Leave a little gap for not touching the quarter panel.
yariseggvvti is offline   Reply With Quote
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Want to lower 1" or so. hmmm piranha0522 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-25-2011 03:59 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
