#1 |
![]() Drives: Toyota Belta Join Date: Nov 2012
there is one 2-Pin connector in the both the front door panels which is not connected to anything.. wire color is i think green and white.. what is that connection for? it is just near to the mirror connector.. i doubt it is for heated glasses?..correct me if iam wrong
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
I've seen those two wires as well. I suspect they are for our optional mirror indicator upgrades. Will post a pic later.
#3 |
i tried connecting indicators to that wire..but they are not working so i decided to make side mirror indicator connection to the side fender indicators..that 2-pin is for something else..may be some expert can tell us what are they for..
#4 |
The extra wires are probably for the power folding mirrors, which are an option on Japanese Yaris.
#5 |
no thats not for folding..my belta comes with 5wire connector (auto folding).. this 2-pin is separate connector
#6 |
OK. If it is not the attached one, then it probably is the one for the turn signals. With some of the wiring like that, the harness is in the door, but the connection between the kick panel junction connector and the fuse panel is not there.
#7 |
#8 |
this is the same connector i also have in my belta door panel.. did you find any information about these two wires?..i need to connect my Mirror Led indicators.. iam thinking to wire them to the fender indicators .. i wish this connector can be use for led indicator..if you found any information then let me know:)
| Toyota Australia releases YRX SEDAN. | Sp33dY | General Yaris / Vitz Discussion | 1 | 08-01-2006 01:19 AM |
| Belta/Yaris Sedan compatibility | fnkngrv | General Yaris / Vitz Discussion | 2 | 07-24-2006 06:02 PM |
