Old 03-30-2007, 08:44 AM   #1
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
I was looking into the idea of getting this, but i came across the idea of the programable Keyless/Sec. System, that has different settings for items, such as windows: Example: A Lexus has the windows set to lower 10% to let heat out of the vehicle when you open the doors to the vehicle, I thought that was pretty cool.
I dont know if they have any setups like that, not to mention has anyone tried to setup an electronic switch in the hatch of the yaris to open with a hit of a button, for say on the keyless? Automatic lift-gate? Just put some heavier duty cylinders to open the gate from close to open?
Old 03-30-2007, 10:03 PM   #2
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
It's possible that you are describing something else, but as a FYI -
When you open the door on a car and the window rolls down and then it rolls back up when you close the door, that's because the door is supposed to seal better/easier that way.
I need to look into getting this system, especially if it's plug and play.
Dragonacc is offline   Reply With Quote
Old 04-18-2007, 05:30 PM   #3
waylandchin
Drives: Toyota Yaris 2007 Sedan
does the vip security system pop the trunk too? or does it just unlock and lock the doors?
also, what the does the remote look like? can you take a picture? I looked in the yaris manual and it shows a key with built in buttons, not a seperate remote attached to your original key.
waylandchin is offline   Reply With Quote
Old 04-19-2007, 05:00 PM   #4
yarisuzr
Drives: 2007 Blazing Blue Yaris
The VIP security is a separate remote. It's actually the same remore (identical) as my fathers 2003 4 door tacoma. Just a lock and unlock. You hit the lock to lock and unlock once to unlock the driver door and twice to unlock all doors including the back hatch. Does not pop the hatch though. It also has an insert in the center concole button holes with a blinking red light and a VIP Security written on it.
yarisuzr is offline   Reply With Quote
Old 04-19-2007, 06:37 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
if you have rs which already has the keyless immobilizer..how must to get the security upgrade...canadian!!
