Old 07-04-2013, 11:37 AM   #19
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
awesome build thread. love your car.
-Derrick-
Old 08-28-2013, 06:17 PM   #20
iwanttobeamole
Drives: 2000 Yaris 1NZ-FE Supercharged
Sneak Peak
More to come soon.
iwanttobeamole is offline   Reply With Quote
Old 08-28-2013, 07:16 PM   #21
underdrive s/c pulley? Sweet!
Old 11-27-2013, 06:21 PM   #22
iwanttobeamole
So.....
it turns out that supercharger RPM is not directly proportional to boost.
I wanted 50% more boost, so I made the supercharger spin 50% fast. What this got me however was about 200% more boost, about 15psi at 2,000 RPM. Too much!
So.. back to the drawing board, I had another pulley made that increased pulley RPM by approx 22%, and this seems to have done the trick. It's installed and going well so far, but the ecu is set to boost cut at about 12psi, which it now hits at about 3500RPM.
Had to tweak the belts up pretty tight but they don't seem to be slipping so that's good.
Tune is booked for next Thursday.
Old 11-28-2013, 01:58 PM   #23
ilikerice
ilikerice's Avatar
15lbs is what i want out of a supercharger. Can that charger hold that much boost?
-Derrick-
Old 11-28-2013, 05:10 PM   #24
awesome
Old 01-20-2014, 03:32 AM   #25
iwanttobeamole
I was a little slack updating this but just before the end of last year I got this sorted out.
Had another pulley made with a 22% increase in diameter, which landed me this result.
(dotted line is the last run with the smaller pulley)
Boost is sitting at 0.9bar (13.25psi)
While the kw figure isn't too high at 89.6wkw (121whp for you non metric types) the torque figure went up another 20%! It's quite something to drive now.
Also worth noting here that it was tuned with reliability and economy in mind on 95 octane, not 98 (which is available here in NZ).
Overall I'm pretty happy with how it turned out.
Here's a bonus pic of my new intake pipe to fit the 55mm throttle body (4 bolt type from an 1zz)
Old 01-21-2014, 05:07 AM   #26
hare
Drives: VITZ RS1500
is it no way to factory bolt on to the 1zz throttle body?
thanks for your sharing,really enjoy it!
hare is offline   Reply With Quote
Old 01-21-2014, 03:42 PM   #27
iwanttobeamole
There seem to be two different sorts of 1zz cable type throttle bodies (as opposed to fly-by-wire ones) One is a 50mm three bolt, and seems to swap to the 45mm yaris one just fine(according to other peoples experience, I never did this) The other is a 55mm 4 bolt type, which, as I was getting a new intake arm anyway, I chose to use as it's larger.
hope this helps :)
Old 02-21-2014, 08:31 PM   #28
abstractmethod
Drives: Toyota Echo
Great write up mate, keep us posted :D
abstractmethod is offline   Reply With Quote
Old 03-18-2014, 05:11 PM   #29
iwanttobeamole
Originally Posted by yaris edd View Post
hi ive just bought a jimze charger and its fucked do you recon there is any chance i could use the mini cooper s charger with my tb and manifold on it? they look different to me but they are both m45 arnt they? cheers
While the model is the same the housing looks quite different. Also I believe the mini S/C has some sort of oil pump built in, so that could complicate matters.
What's wrong with the s/c you bought? I know that sometimes the teflon coating fails but that can be re-done.
Old 08-09-2014, 07:50 AM   #30
iwanttobeamole
Finally got around to making a little video of the car.
Enjoy :)
Old 09-03-2014, 04:14 PM   #31
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Great build up.
Are you still using a standard gearbox?
rob323 is offline   Reply With Quote
Old 09-03-2014, 05:22 PM   #32
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
LOVE the sound! I've finally gotten my S/C build under control and it's been phenomenally fun to drive.
Old 09-11-2014, 04:14 PM   #33
iwanttobeamole
Originally Posted by rob323 View Post
Great build up.
Still using the stock gearbox. It seems to be handling the extra torque fine.
I've just been offered a 6 bolt TRD LSD for it, but sadly I'm now selling the car to make room for another project so I'll have to decline. :(
If I had the garaging I'd probably keep it cos it's SO MUCH FUN!
Old 09-11-2014, 08:12 PM   #34
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Nooooooo, keep the Vitz dream alive :(
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 02-18-2020, 10:53 PM   #35
iwanttobeamole
So ... this happened.
Old 02-19-2020, 06:04 AM   #36
iwanttobeamole
Ok so that was a bit cryptic.
I've fixed the links in the build thread now, driven by a seething hatred for photobucket.
Here's the short version
I sold the car in ~2014.
In 2019 I saw it come up for sale but, it had been re-shelled (assume it was crashed?) and it was a bit shabby. While I liked the idea, didn't want the headache.
Turns out a friend of a friend (Genuine GC) bought it, tidied a lot of the shabbyness up. I got talking to him at the time he bought it and gave him the history and the car and offered any help I could assist with, but also mentioned the old... " if you sell it, tell me first"
Well....
His wife's just had baby #2. He emailed me last week and asked if I was interested.. then made me an offer I couldn't refuse..
My circumstances have changed and now I have a bit more space, (but no more time).
So now I have, most of (the important bits) my old car back.
I've just drive down country with it (about 500kms) and aside from the supercharger being slightly skewed so the belt hops over one tooth, it's running very well.
From my memory of 6-7 years ago the power is still good, the seats are still terrible, and I think the new chassis is better than the old one (less rattles etc)
All the important pieces have been swapped to the new shell so that's good!.
I always felt like the project wasn't complete, but my dream car came up (JDM Honda Integra DC5, with a K24/K20 hybrid motor already done) came up. (which I've now supercharged also....) and at the time I didn't have the space, time , or money to deal with a second project car.
Now I have the chance to complete the project and hopefully realise it's full potential.
Here's the list.
  • Full exhaust ( currently most of it are stock at I believe 1.75")
  • Intercooler - The aim is to modify the manifold or build a new one that allows for the charge to be intercooled
  • Sort out VVT-i which seems to be weirdly non-effective. (research required)
  • Fit wideband
  • Tune
Obviously having dredged this post up from the dark ages, I mean to keep it updated, so, I guess, Watch this space.
1nzfze, jimze, supercharged, supercharger
2NZ-FE Supercharged Limits iwanttobeamole Forced Induction Forum 8 11-21-2016 04:59 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Supercharged 2nz-fe VVTI tuning iwanttobeamole Forced Induction Forum 2 09-02-2012 07:30 PM
++JIMZE SUPERCHARGER++ MANSETH Forced Induction Forum 17 07-07-2010 12:47 AM
