Old 05-01-2013, 04:12 PM   #19
sant_ashu
Drives: toyota yaris 1.0 t3 2004
well i will never ever find tht out...as it was a recent private buy and I spotted that within couple of days after buying the car, but did not knew if it was a hole to be closed or just some pressure relieving hole. But when the gear popping problem started, I got it checked from the garage n was told gearbox fkd n need replacement I stopped using the car and wondering what to do as the replacement cost was huge. then I started the thread here, kou 's pics helped me and made my doubt clear that its the filler plug hole n must be closed. rest is history buried in this thread.
yarisworld rock.
GRADE: TRSTD: STANDARD TYPE (02/2003- )
PRODUCT: FRP: PRODUCED AT TMMF
DRIVER'S POSITION: RHD: RIGHT-HAND DRIVE
ENGINE: 1SZFE: 1000CC 16VALVE DOHC EFI
TRANSMISSION: MTM: MANUAL TRANSMISSION
GEAR SHIFT TYPE: 5F:MTM, 5-SPEED FLOOR SHIFT
NO.OF DOORS: 3D: 3-DOOR
COLOR CODE: 1E7 TRIM CODE: FC11
sant_ashu is offline   Reply With Quote
Old 05-02-2013, 09:12 AM   #20
bronsin
bronsin's Avatar
Did you change the oil in there? If not drain the old stuff out and fill with new. If the oil that came out is dirty/has junk in it report back here for further instructions...
gear pop jump neutral
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Remote Start Problem: Mechanical, Like in Gear Lil Abner DIY / Maintenance / Service 10 07-24-2011 06:49 PM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
