#19 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
#20 |
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Will be heading out to Ohio again in a couple of weeks, same 'ol same 'ol, leave at night only this time might be a weeknight so I am more likely to run into night construction.
I WILL NOT MISS THAT BLOODY $1.00 TOLL IN EASTON, PA. AGAIN! For the life of me I still don't remember how the heck that happened. Will pull over for a break, coffee and gas at Miranda Hills at the Wilco Hess, just off 81. and just shy of Harrisburg which is almost exactly the halfway mark for me. About 370 miles. If I am having a good run I may push it past 400 again. Right now with about 75% city driving I am just under 38 mpg. ^Bronsin, there are two crazy climbs on this drive, well there are several but these are back to back, the second and less severe is right over the Ohio River climbing up and out entering Ohio westbound. The first, and the only time the Yari has ever downshifted on its own with the CC on is the climb just before that one. I think it is in Triadelphia, W. VA. westbound, it shocked the hell out of me I thought I was going to stall out on the grade up. CC comes off before those now. Last edited by NEexpat; 05-20-2013 at 03:04 PM. |
#21 |
I am fortunate to live in NJ in the southern part where its completely flat!
I wonder is there a mod to prevent the auto trans downsshifting on grades? ![]() Have you considered cc out and manual control back to compare the two? You can get creative with your foot but with cc not so much.
Synthetic Oil: Its All In Your Head |
#22 |
^Not really. For this trip which is 12+ hours I keep the CC on as much as possible. Plus I've tried the CC on for a tank and no CC for the next with almost an identical driving profile and I couldn't match it.
I killed it at the Tappan Zee Bridge on the way home on the last trip and I saw the avg. drop for the rest of the trip home. I'll be happy with anything over 42 mpg. |
#23 | |
#24 |
Leaving for Columbus, OH again tonight. Will post the numbers when I get them.
#25 |
Drove back from Columbus yesterday. Here are the numbers for the outbound leg.
738.3 miles 17.1 gals. 43.17 mpg. Btw- Correction I stop at Manada Hills, not Miranda Hills. It is about the halfway point for this trip. Caught a little traffic just east of Columbus for about 10-15 min, otherwise nothing. NOW here are the return numbers. I double checked them. 744.5 miles 16.047 gals. 46.39 mpg. It was warmer, left at noon, Didn't run the A/C. I knew the mileage would be good when I didn't drop the 1st. bar until around 104 miles, 2nd dropped at 176. I kept the CC on all through NY and CT unlike the previous trip. No traffic delays at all. This is the best mileage I have ever achieved. What a great little car! I've got some pics. on my phone of the UltraGauge, Odometer, gas pump etc. Have to download them. At one point the UltraGauge had my MPG 49.4 lol. I only use the actual pump numbers, and always stop at the first click. I am convinced that the ambient temp is the most important factor, at least for me, to get those kind of numbers. Cheers. Last edited by NEexpat; 06-23-2013 at 04:00 PM. |
#26 |
Yes the hotter the better as far as temperature.
I just got 35 mpg all short distance (less than 7 miles a trip) stop and go driving.
#27 |
********Just a follow-up**********
I'm not going to start as new thread or comment on another, i'll just follow-up on mine. My mpg right now, almost all city driving A/C on stop and go, traffic etc. is now at 34.2 mpg. Just got an oil change 2 weeks ago, with bottle of Techron. Tires at 38 psi. So there is over a 12 mpg. difference from what I logged in on my most recent trip to Ohio. 12 mpg. difference, and i'm not concerned a wit. So to all those who feel their mileage is not what it should be, my advice for what it is worth, take it or leave it, is what it is and always has been. Fill up and go for a 4 or 5 hour highway drive with the CC on, and then check your mileage. cheers, BTW- I will heading out to OH again in about 6 weeks, and I am so convinced that my mileage like almost everyone else's here is primarily a direct result of ambient temperature and length and type of drive/commute. I probably won't even log my mileage here on my upcoming trip because it has been pretty consistant. Low to mid 40's depending on the temperature, on an automatic. Last edited by NEexpat; 08-02-2013 at 05:27 PM. |
#28 |
Just washed the egg, windows Invisible Glass, check the fluids, tire pressure etc. Check, check, check and check.
Yup, getting ready to head out to Blacklick again. You guys are probably sick of this thread by now. Same old stuff, 735 miles +/- each way, one stop, halfway point, CC on all the time, get through CT,NY,NJ in the dead of night and based on the temp outside I would be surprised if I wasn't running 40-42 mpg for the first 6 hours or so then 42+ when it warms up outside. Gotta be extra vigilant this time of year for deer. Currently running 35.4 mpg almost all city. |
#29 |
No way!
Keep it coming dude! Whats invisible glass? Sounds good!
#30 |
#31 |
Stoners Invisible Glass. HERE
It's the glass cleaner I use, easy spray on, or spray on a rag and no streaks. I had a windshield replaced a few years ago on my Honda and that is what the glass guys were using. |
#32 |
Got back a couple of days ago.
Here are the numbers: Outbound leg - 40.5 mpg Return leg - 41.8 mpg MPG's about what I expected, a little low but it was cold out. I was checking the air intake temps. (it is some of the things I do on 12+ hour drives) as the temps dropped so did the mpg's. The gals./hr. number would increase as the temp dropped. Odd thing happened just before I left. I was filling up for the trip home and the pump kept clicking off, at 2 gals. at 4 gals, at 5.8 gals, when it got to where I thought it would be full and it clicked I stopped so as not to overfill. Set UltraGauge to full tank, zeroed out the mpg and reset trip computer functions. Had hoped to get to the Cabelas apprx. 417 miles down the road before I had planned to stop for gas and a bite to eat. Was at 388 miles and had been driving on 2 bars for quite a few miles and decided why chance anything, plus all the clicking at the gas station left me unsure as to whether or not I had actually filled up. Turns out the UltraGauge was right had apprx 2+ gals. left. Could have easily made it to my pit stop. But again, when in doubt stop and get gas, plus I am not a big fan of driving with that little gas and who knows what other stuff is in the bottom of the tank, etc. Again, great little car. Of course the UltraGauge only knows what I plug into it, I just guessed the tank was pretty much full. Last edited by NEexpat; 11-06-2013 at 07:57 PM. |
#33 |
Just out of curiosity, does Ohio require a full 'sleeve/seal' around the nozzle? No requirement at all? (I've been to Ohio, but not since 2007 (IIRC), so I don't remember what the pumps look like (California = many sleeves almost made of steel (hard to hold away) and New Mexico (unless changed since 2010) = many, many pumps with no sleeve at all)).
I paid $2.709 gal. for gas a couple of hours ago (Kroger at US 290 and Spring-Cypress Rd -- cheapest in the metro area per Gas Buddy ($2.739 - 3 cent Kroger Card discount). This is the least I've paid for gas in months IIRC off the top of my head. |
#34 |
Yes WHY people drive down to a blinking bar is beyond me. So many ways that could be trouble!
Gas 299 here in NJ woo hoo!
#35 |
Nook. I know the recapture system you mentioned, we have it here in the Commonwealth. They don't have that in OH. I think it was just a faulty pump handle.
I would have done better on the way back but three times I got hung up in night construction in CT. At one point I turned the car off and sat for a good 10 min. Gas in OH was $3.29 the day I filled up, Here in MA. Shell station $3.25, Hess $3.19 Two things I still want to do with the egg, at some point install the Fiamm El Grande horns and then dive into the world of touch up paint to address some of little issues emerging on my front end. Looked into this in the past and watched some real experts work on Maybachs and Benzes. If I learned anything it is that there is no "magic" pen that you run over the scratch or chip and voila' gone. Even a clear coat pen has to be smoothed out and buffed up. It is a process and to do it correctly requires time, time, patience and the secret, (as revealed to me by a touch up master)........................................... toothpicks, really lots of toothpicks. Last edited by NEexpat; 11-07-2013 at 12:42 PM. |
#36 | ||
I drove from Newport, RI to Piscataway, NJ (through Providence, RI and Nyack, NY) on October 24th (late afternoon and night) and there was much highway construction around Providence and in CT. Trying to get as much as possible done before too much inclement weather?. I ended up driving the Merritt/Hutchinson River (no construction, and of course no trucks) from Stamford to I-287 for the latter part of the east of the Hudson segment of the trip
