Old 05-03-2013, 12:32 PM   #19
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
You guys are funny (and thanks for the kind words).
We do MINOR installs on customer cars, if they come in person and it's something basic like a sway bar, HID kit, intake or axle-back exhaust. It also depends on how hectic the day is.
Thanks to Jeff, I have a bunch of FR-S guys dropping by these days, which is awesome.
so what you are saying, is that you are glad you got an FR-S and not a Fiat.
Old 05-03-2013, 01:07 PM   #20
Haha
Old 05-03-2013, 01:41 PM   #21
Originally Posted by 47_MasoN_47 View Post
Ebay car parts are kinda risky. Things like ball joints and stuff seem to be fine, but I just wouldn't feel real good about telling anybody to put any of that knock off stuff on their engine. I've had my AFe intake from Garm for several years and love it.
Looks like your engine grew a tumor. You should take it off and give it to me to dispose of
Old 05-03-2013, 10:43 PM   #22
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I wouldn't buy a knock off. Go with something proven, that someone actually took the time to make sure actually makes power.
Colin Chapman disciple
Old 05-22-2013, 10:02 AM   #23
06silveryaris
Drives: 2006 yaris
I had bought a chepo intake for a Yaris I had a while back just like the one on the link and it had good fit came pretty complete. Its hit or miss sometime with these chepo parts
06silveryaris is offline   Reply With Quote
Old 05-22-2013, 11:25 AM   #24
^ That's for sure.
Old 06-16-2013, 09:11 AM   #25
mrtobs1988
Drives: 2009 toyota yaris white
hello, i have a question. i was at auto zone yesterday and bought a filter and necessary tubing for installing it. as i got done carefully putting everything together, making sure everything was connected and in place, i tried to start my car but it would die right after, just struggle for a few seconds and then just die. i tried different things like changing the tubing or covering parts of the filter to let less air through but with the same results. at one point i got it so that the car would idle fine, but when i pushed on the accelerator it would die after reaching higher rpms. i finally gave up, put the original parts back on and returned the new ones to the store, so no financial harm was experienced luckily. now everything's working fine, which makes me think the problem wasn't an improperly connected or damaged MAF sensor. does anyone know what my problem is? does the exhaust have to be replaced to assure the extra air entering the engine has a larger pipe to exit? i have no idea.
i appreciate the help and talk to you soon
mrtobs1988 is offline   Reply With Quote
Old 06-16-2013, 12:56 PM   #26
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Welcome to the forum, tobs,
I'm glad your car worked fine after going back go the stock filter. What kind of filter did you get from Auto Zone? Did you disconnect the negative terminal from your battery so that when you reconnected, it your computer would relearn the new operating parameters created by the new filter?
Old 06-18-2013, 05:22 PM   #27
mrtobs1988
hey thanks for the help. it was a spectre filter, something i found on the shelf. i did not disconnect the negative, but do you think that's the problem?
Old 06-18-2013, 07:45 PM   #28
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've looked at off-the-shelf parts and it's almost all 2.5" or bigger. If you used a larger section where the MAF goes, that messes up the air velocity, which makes the ECU think it's not pulling in enough air. That said, I think it would have thrown an error code if there was something really screwy with it.
Old 06-18-2013, 09:52 PM   #29
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Probably had the maf in backwards
Dont half ass shit on your car if you dont know what your doing. Buy an engineered intake system from Garm and get real, SAFE results that wont fuck up your car. $1000 motor or trying to save $50 with autozone crap
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-19-2013, 12:18 PM   #30
tooter
play every day
tooter's Avatar
Maybe... It's always a good idea to take off the negative cable to let the ECU reset itself whenever you make any changes to your engine. Then it will start fresh and learn to adapt to the new operating conditions.
Old 06-19-2013, 01:00 PM   #31
mr_miles
Drives: 2013 Yaris
late chime in - but I own one of those ebay intakes (came with the white yaris when I bought it). it's identical to the AEM, but probably built with less quality in mind. I broke the weld on mine for the mount - likely due to the fact that mine is bolted directly to the frame with no rubber spacer. apparently the engine moves a lot :p
Old 06-19-2013, 02:25 PM   #32
^ yes, it does move quite a bit (unless you purchase our TRD trans mount/roll stopper). Make sure that the cold air intake you choose has the ability to move via rubber bushings/stoppers or other means. Short ram is a little more forgiving in that respect.
Old 06-19-2013, 05:46 PM   #33
mrtobs1988
yeah man the maf was good, no half assing here. i don't see what's wrong with making cheap crap work, and if what we're talking about is a 5hp increase i don't see the point in spending hundreds of dollars on it. also, as long as the filter prevents stuff from entering the engine i don't see how it could compromise it. in the end it's a tube with a filter, there's only so much engineering you can do to that
Old 06-19-2013, 06:44 PM   #34
tooter
play every day
tooter's Avatar
The only limitation on that the tube diameter is 2 1/8th inches inside diameter at the MAF sensor. Everthing else is up for grabs. My truck intake is swedged down in the only place it matters, at the MAF sensor.
Thanks for the good deal Garm... it works great!
Old 06-19-2013, 07:28 PM   #35
mrtobs1988
ah thanks crankyoldman and tooter, i think that might be it.. i'll have to see if they got the right one
Old 06-19-2013, 07:53 PM   #36
mrtobs1988
do you know what the diameter is for a 09 yaris?
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Intake Question... :/ RacerFreakXXX Performance Modifications 22 10-03-2009 06:47 PM
Air Intake Question ruimond Performance Modifications 17 11-29-2008 06:07 AM
intake question and suggestions Adriaan Performance Modifications 2 01-31-2007 04:54 PM
