Old 05-20-2013, 06:50 PM   #19
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
I could actually make you a device that works off the VSS (speed sensor) wire. My Demetricifier (which lets a km cluster work as a Mile one) interprets that signal, so driving a beeper instead of manipulating that signal would be very easy.
I did some research of what is a speed sensor wire, it exactly like you said, outputs a signal to instrument cluster. If so any chance to just tap into that wire to the positive lead, and the negative goes to the yellow handbrake wire?
caineroad is offline   Reply With Quote
Old 05-20-2013, 08:22 PM   #20
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
Now that you mention the Hand brake alarm, I don't remember hearing one nor even seeing a light.
Maybe it's just my old age.
screenprintr is offline   Reply With Quote
Old 05-20-2013, 08:36 PM   #21
You can't drive something with it, as it will drag the signal down. You could use a transistor to drive the buzzer off of the speed signal, since the signal sits at ground when the car is not moving and pulses at a fairly high frequency when the car is is motion.
Factory Alarm on my '08 Liftback is Too Sensitive! alex_melodymaker In Car Entertainment + Electronics (audio / video / alarm) 9 06-07-2011 03:21 PM
Alarm Wiring Advise Needed Lil Abner In Car Entertainment + Electronics (audio / video / alarm) 14 09-26-2010 10:11 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
Rant! Damn car alarm installers, trying to rip me off!!!! W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 18 11-21-2006 09:18 PM
