Old 05-23-2013, 09:50 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
You can see some tire deflection on my previous rear suspension vid. No where near as bad as it is in the current video.
http://www.youtube.com/watch?v=504Pl...etailpage#t=7s
Old 05-24-2013, 12:43 PM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
so how does it feel? Butt dyno
-Derrick-
Old 05-24-2013, 08:29 PM   #3
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Thank you Namer for further pushing the development on the Yaris. :)
You still need a CAI, though!
Old 05-25-2013, 01:22 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Gotta make sure I can get power down before I turn power up
Getting the car ready for the race this weekend, will have a better idea on how it works when everything is said and done.
Old 05-26-2013, 06:15 PM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
First test is in...and I don't know how to drive the car now.
Biggest thing that comes away from this to me is I can trail brake now, the car doesn't want to get loose on liftoff, so it doesn't rotate all that well. Not a bad thing but something I kept finding myself anticipating but never happening.
Overall it behaves like driving a RWD mcstrut car, on lift off or braking it doesn't want to turn but power down it turns in really really nicely, I think part of that is springs but I don't know what else to attribute it too. I can mat it wherever I want now, the inside tire will not spin on anything aside from a clutch dump. Its going to take some relearning of the car but I think its working exactly like I wanted it too. I need to play with the springs again but the rates I was running were fairly close to what would be a good match.(Thanks again Jason)
The suspension video is really cool to watch and a touch disappointing as well since I don't have wide enough rims.
RSB Video
http://www.youtube.com/watch?v=whM3f...ature=youtu.be
Fast Run
http://www.youtube.com/watch?v=kItBgm8kuJs
Old 05-25-2013, 01:24 AM   #6
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Wow, finally, someone who realizes how a real sway bar works! Nice job.
Old 05-26-2013, 06:59 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
id be worried about all the deflection using the tow hooks as mounts. In your videos they move around ALOT...not designed for side loads. I would attempt to build strong brackets that bolt to the frame.
I have damn near on command lift-off oversteer with my Yaris sedan with the UR 23? mm RSB...but i also have more weight to fling about, so that gives me leverage.
I like your idea, I just think it needs refinement. Good work!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-26-2013, 07:15 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
I need to stick a tape measure up there to verify but I think some of what looks like deflection is the gopro flexing on the bumper.
There really isn't that much load going through the toe hooks it really shouldn't exceed 500 lbs which 2 stamped 1/8 pieces of steel should be okay.
Lift Off oversteer is mostly bad in my situation, controlled rotation is good but not being able to get confidence the car isn't going to spin is bad. Of the fast STC guys who've driven my car, that was the one major complaint they had was that with the 19mm TRD bar, the car wanted to rotate too much.
As a double check I pulled one mount of the swaybar and pulled the bar like a breaker bar. The energy bushing and my mount deflect and I wasn't really able to get the toehooks to move. Those toehooks must be designed to pick the car up individually, they seem way overkill for a 2400 lb car.
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 02:14 AM
