Old 06-11-2013, 11:39 AM   #1
esse10
Drives: 2009 yaris 2 door
bp blaster
I use BPblaster spray everytime I work on my suspension and it works like a charm for removing bolts. By the way all you needed was a high grade bolt at the local hardware store, grade 8 - 10 hardened steel. It would've been cheaper than the dealer price for sure. If you gonna do your own mechanic work you might want to invest in some good quality tools, makes a diffirence.
Old 06-15-2013, 11:35 AM   #2
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
It does not matter if you use a socket once or twice a year! If it's cheap(India, China), it will cost you more time then the cost of a fancy socket set.
Originally Posted by Shinare View Post
Guilty as charged. All my tools are "el cheapo" as I MAY use a socket once or twice a year.
I started out with a many pointed socket and when that started to slip I changed to a 6 point 14mm I found under a bunch of other sockets I didn't know I had. It looked pretty cheap as well tho. No brand name even on it heh. Then it started to turn on the head... guess I should have started with the 6 point. Live and learn... heh
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 06-10-2013, 05:52 PM   #3
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Thanks all, the bolt will arrive on Wednesday (ordered it from toyota dealer) and talked to my father-in-law, he has a mechanic buddy that has the tools to remove the rounded bolt for me (so I don't have to buy just for one use). I'll take it to him and hopefully by this weekend this will all be a distant memory, heh.
I have some "Liquid Wrench" at home. I will put some of that on each day over the course of the week. Hopefully that will work better than the WD40. That way its nice and lubed up for the mechanic guy to twist off.
Old 06-12-2013, 09:24 AM   #4
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Also make sure you tighten it up real tight to avoid that ear bustin squeal!
Old 06-15-2013, 10:07 AM   #5
Shinare
Shinare's Avatar
Got the bolt finally but forgot to ask what to torque it to. Anyone know.
Old 06-23-2013, 06:11 PM   #6
Shinare
Shinare's Avatar
Well, bolts out and belt is on!!!!! Thanks to all here tht helped me. I finally broke down and bought the expensive roundedbolt set from pep boys as pictured. It finallybroke loose after many squirtsof liquid wrench and a long cheater bar. (Thought i had broke the bolt or wrench how loud it snapped when it finally broke.) Thans again everyone for the support and ideas that gave me the courage to tackle what i thought was an insurmountable problem.
Ps there was this white powder in the threads of the bolt. Some gift of thread lock from someone previous?
Need new Serpentine/Auxilliary belt ras3448 DIY / Maintenance / Service 21 07-16-2013 05:11 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Broke Part on Engine Changing serpentine belt. theeggrocks DIY / Maintenance / Service 5 04-16-2012 12:27 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
