Old 08-16-2013, 10:30 AM   #19
33OH
Drives: '08 Yaris
Wouldn't you think it would throw a code for any of those? Or not necessarily?
I'd hate to just start throwing parts at it, but sounds like that's what I need to do.
Old 08-16-2013, 10:56 AM   #20
If any of those items were bad it would throw a code. If a coil pack was going by not completely bad it would not. With the fuel system as well, it would not throw a code until it got bad enough to start misfiring.
Before replacing parts I would do some additional cleaning and diagnostics, like doing a proper cleaning of the injectors, checking fuel pressure, etc.
Old 08-17-2013, 09:13 PM   #21
bail_w
Drives: 2007 Toyota Yaris LB
my engine was shaking after i disconnected the battery.
Edit: nvm, it still shakes after a while of idle.
bail_w is offline   Reply With Quote
Old 08-31-2013, 06:54 PM   #22
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
If it doesn't get better quickly on its own, then clean the throttle body. There is a TSB about rough idle after disconnect where the solution is to clean the carbon deposits from the throttle body.
This. I've had rough idle and stumbling acceleration for a few weeks now, with the occasional P0300/P0301/302/303/304 and the odd P0171. Finally got tired of it stalling at intersections and pulled the TB off. Not unreasonably filthy overall, but enough had built up around the rim to prevent it from getting the right amount of air at idle, as well as some sticking when opening/closing. I disconnected everything but the coolant lines because the TB cleaner specifically said NOT to use it on forced induction systems. A few squirts of cleaner and a minute with a shop rag cleaned it right up. Idles just fine now and responds much better to pedal inputs.
Old 08-31-2013, 09:35 PM   #23
Tedtalker
Drives: 2007 Yaris Sedan
Thanks Scott, I'll check the throttle body out. I remember it had some salt deposits on it anyway, so it's a good place to start. MAF was pretty damn clean, just had it out, so I'll check the TB first.
My MAF looked clean as well but after spraying with MAF cleaner there was noticeable smoothness and more power felt. Those little silver wires are very sensitive it seems. What can't be seen with the naked eye, but is obviously there is amazing to me.
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
