Old 07-31-2013, 03:39 PM   #19
Jason@SportsCar
The lead on the bolt is way long, and I recall the tip is not even the same diameter as the main body of the bolt. On our 2012 we took about 1/4" off the bolt, problem solved. Had no problem putting the shorter bolt back in.
Old 07-31-2013, 04:12 PM   #20
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Garm - Is there any way to identify these before hand? I ask because I just ordered one from you guys and don't want to have to go through the trouble of trying to install it only to find it's defective.
Thanks!
If you bought it from Garm I doubt you will have a problem. I bought mine from him a couple years ago. Once I put that gasket thing back in, it worked fine.
Old 07-31-2013, 04:49 PM   #21
mario98c
mario98c's Avatar
Old 07-31-2013, 05:53 PM   #22
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Megan Racing header is cheaper, and fits great, since you can't see it anyways no point in getting a shinny one, just get one that works.
Old 07-31-2013, 06:06 PM   #23
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
Garm do u have the correct dc sports header on stock?
Upgrades: AFE SRI. Tanabe Touring Medalion Axleback exhaust. Micro Image OEM Sized Lightweight Pulley. DC Sports header.
DJYojimbo is offline   Reply With Quote
Old 07-31-2013, 09:02 PM   #24
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by BEEF View Post
I'd go without the header for the show (put the factory one back on) and send it back. The longer you keep it, the harder warranty stuff will be.
I am actually a big fan of the Weapon-R (I has one) and would recommend it. There is also a huge price premium between the two... and I haven't heard of any issues with them.
Same here.
Their assembly is impeccable. The runners are joined so precisely they form a knife edge sharp enough to cut your finger.
A day out with mechanic went wrong- Right arm problem talhahs DIY / Maintenance / Service 6 05-17-2013 05:20 PM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
