Old 04-01-2007, 02:16 AM   #1
JDM_EK3
JDM_EK3's Avatar
Drives: 2006 Toyota Yaris RS
Yikes.... Regardless of your results, I would NOT follow any of the advice given.
First and fore most, when applying a degreaser your engine should actually be warm to the touch prior to application. Depending on how harsh of a degreaser you use, the time of "soaking" will vary of course before rinsing it clean.
Also the fact that you're misusing in extremely excessive amounts, products that are ment for interiors and tires on your engine is horrible detailing etiquette. Have you ever noticed what occures to your tires with the use of most tire "sheen" products? (there are exceptions of course) Due to the heat, they actually end up turning rubber a nasty brown/yellow colour after time.... would you honestly want that occuring with all the rubber components of your engine, such as mounts, hoses, etc.?
Lastly, once soaking up the majority of water after washing an engine bay, you can actually let the car run for a said amount of time to quicken the drying cycle.
JDM_EK3 is offline   Reply With Quote
Old 04-01-2007, 03:36 AM   #2
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
No-one's making you
The Engine Cleaner I use specifically states to apply it to a cool engine, and logic dictates that it's going to be difficult to get much soak-in time if the engine is warm or hot. Maybe it's just a matter if what's warm to you and what's warm to me? We never get daytime temparatures below 30c (86f) here, so I couldn't comment on whether effectiveness is reduced at lower ambient temps.
It cannot be due to heat, otherwise my tires and engine would *always* be brown - It's 41c (106f) as I type this BTW :) I have seen what you're describing though, and have always attributed it to people who think that tire shine products are somehow or other a substitute for cleaning. From what I've seen, layering tire sheen over old dirty tires time after time, is what leads to brown tires.
For this one, I'm going to let some pictures do the talking.. Here's my last car, at 2 years of age, having had this exact type of engine detail peformed on a weekly basis (so 104 times):
Good advice, thanks!
Razr is offline   Reply With Quote
Old 04-01-2007, 01:05 PM   #3
JDM_EK3
JDM_EK3's Avatar
Then unfortunately the product you're using isn't that great of an engine degreaser. Most well known engine degreasers, will even go to the extent of asking you within their instructions to warm up the vehicle. The reason they would like your engine warm to the touch, is that it actually helps loosen the build up and helps in preventing the engine degreaser from evaporating too quickly.
Old 04-01-2007, 01:43 PM   #4
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
I tried degreaser when the engine is hot once...
Well... its an old honda civic "93" my buddy used to own... well I sprayed that "solder seal" engine degreaser when he came to my place and ask me to wash it bcoz his going for a group meet, so I hustled and sprayed it with E.D. and about 3 seconds after I sprayed it, nasty smelling smoke came out... then I hit the freakin header! and it went to flames! quickly he grabbed his "NOS lookin" fire extinguisher and sprayed the hell out of it!
the engine lining he installed got melted a bit and he told me to just stop it... and he just went to the club meet with a nasty lookin engine with a burnt hood padding...
what I'm saying is some cars need the engine cold just to clean it safely...
THE YARIS: TINY BUT PRICEY!
BUT YOU JUST GOTTA LOVE IT....
forpinks is offline   Reply With Quote
Old 04-01-2007, 05:21 PM   #5
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Why degrease an engine that isn't greasy? As a note, those degreasers are powerful, so be careful not to get them into parts with bearings (ie. the alternator pully, A/C compressor pully)...
I just use low pressure water every time I wash the car and my cars stay nice and clean under the hood. Yes, I'm careful where I spray.
I would only clean under the hood by this method if I were tring to sell the car. Your pictures look great!
Old 04-02-2007, 12:09 PM   #6
JDM_EK3
JDM_EK3's Avatar
The engine is not ment to be "HOT", it's ment to be "warm to the touch".
Old 04-01-2007, 08:39 PM   #7
Razr
YRS WHOR
Razr's Avatar
I'm sure there's better/more expensive engine cleaning products out there, but it does the job just fine - the proof is in the pudding, as they say
Old 04-02-2007, 10:23 AM   #8
Razr
YRS WHOR
Razr's Avatar
The Camry will be fine as well.
As for the belts, it's simple - look at them, understand where they are, then don't spray any dressing/protectant on them :) The engine cleaner and the water don't pose a problem for your belts.
Are you allowed to use a watering can with the water restrictions, or are all forms of car washing prohibited? If a watering can can be used, that'll probably do the job - you're really only rinsing off the engine cleaner.
Old 04-02-2007, 08:53 PM   #9
jaspie
Lil White her name is ~
jaspie's Avatar
Drives: White YRX 5DR Hatchback 2006
We are only allowed to use a water bucket to clean our mirrors. car plate and windows now ~ We just reached Level 5 water restrictions >_< ~ Which means we can only have 4 minute showers ~
Thanks for the help ^_^ ~
Jaspie ~
jaspie is offline   Reply With Quote
Old 04-02-2007, 09:26 PM   #10
Razr
YRS WHOR
Razr's Avatar
car plate? 'sif you'd go to the trouble of letting speed cameras get a good shot of your car if you're not allowed to wash the rest of it :P
Old 04-02-2007, 09:45 PM   #11
jaspie
jaspie's Avatar
Agreed ~
Jaspie ~
Old 04-02-2007, 11:00 PM   #12
R0ME0
Drives: '00 Toyota Celica GTS Turbo
Sweet! Is that the stock engine cover or did you add stickers to the VVTI part to make it red?
R0ME0 is offline   Reply With Quote
Old 04-02-2007, 11:38 PM   #13
jaspie
jaspie's Avatar
I'm pretty sure it's stock ~
*goes check my engine*
Hmm....mine's silver ~
Jaspie ~
Old 04-03-2007, 02:26 AM   #14
Razr
YRS WHOR
Razr's Avatar
Red was standard on mine..
Old 04-03-2007, 08:16 AM   #15
yup, for some reason it looks like all 1NZ engine covers have some red VVT-i lettering over here...
The red color alone must bring the engine's power up a few horsepower!
Old 04-03-2007, 06:44 PM   #16
Razr
YRS WHOR
Razr's Avatar
Well actually I've seen the Thai market Yaris rated at 109HP, while the North American Yaris is rated at 107HP, so there might be some truth in that.. or maybe someone just made an error in the conversion from kW
Old 04-07-2007, 06:37 AM   #17
Dude there's like 5 different actual horsepower units and methods of calculations. PS, BHP, HP are the most common, but most end up within about 5% of each other, so it's not too bad. I think this is the cause of this slight difference in ratings
PS. For more information:
http://en.wikipedia.org/wiki/Horsepower
Old 04-07-2007, 04:30 PM   #18
MDF
MDF's Avatar
Drives: Getting a Yaris soon
I brought my car into the shop once and the guy did it for me (since at the time I had no clue how to do it myself...)
He kept the engine running, put a plastic bag over something, sprayed a whole can of degreaser, then hosed everything off...
MDF Yaris: I live my life a quarter mile per gallon at a time...
MDF is offline   Reply With Quote
