#19 |
![]() Drives: 2010 Toyota Yaris 4D Hatchback Join Date: Nov 2013
Weird, on amazon those components come in a set of 4. I wouldn't know what to do with the extra set, LOL. I'll see if I can get them in a set of 2 on Amazon, unless you were to recommend a different set?
#20 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
for the price.. install them in the rear without the tweeters.. that will give you extra boom
You would need a lowpass filter though, and get rid of the stock cross-overs. |
#21 |
That amp would still work. The load would be 2ohms and that amp will do 160wrms @2ohms.
80wrms to each speaker (4 speakers) will sound good. Only issue I see is lowest you'd want to cross these speakers is 60hz. So you'd have killer Midbass. So you would deff need a subwoofer in the future.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#22 |
adding them to the back sounds like a good idea...now just to place the order!
#23 |
Get the model number of the headunit and cross reference it over at Crutchfield to make sure it fits and which face kit they recommend. Scosche or Metra double din kit. Just gonna be some plastic pieces tht fit around the radio
#24 |
Any progress?
#25 |
Going to be placing the order for a Christmas present to myself!
#26 |
Okay where do you plan on installing the amp. If you plan on putting it under your Passenger seat 8 Gauge wire will be all you need for a mids and highs amp. I'm going to list two diff kits KCA from Knu Konceptz is rated at 50 amps. Or if you go with OFC it can carry even more current. So you pick which best fits your budget.
Knu KCA http://www.amazon.com/KnuKonceptz-KC...nceptz+8+gauge KnuKonceptz Kolossus 60 amps of current http://www.amazon.com/KnuKonceptz-Ko...nceptz+8+gauge What i recommend for a small subwoofer amp that will accept 4 gauge wiring (For the future) http://www.amazon.com/KnuKonceptz-KC...nceptz+8+gauge Wire harness for your Radio http://www.amazon.com/Metra-70-1761-...ype=automotive Okay this one i'm not 100 percent sure on cause i have never done a double din on my Yaris. So if you are in fact going to get that double din we'll need to double check it. Face Kit http://www.amazon.com/Metra-95-8202-...d_bxgy_e_img_z
#27 |
I think I'll go with the OFC one...sub in the future though not now. A tad out of reach money wise :P
As for the placement of the amp, definitely under the passenger seat. I can't take away the precious cargo space we have, lol |
| WTB> toyota yaris 2010 hatch OEM body kits | Adward10 | Willing to Buy by private party | 0 | 03-10-2013 12:30 AM |
| OEM roof rack mounting rubber pad replacement | Yai | Cosmetic Modifications (Exterior/Interior) | 3 | 12-22-2012 12:01 PM |
| WTB 2010 Liftback Blazing Blue OEM S Lip Kit | bad_bwoy007 | Willing to Buy by private party | 0 | 01-24-2012 08:43 AM |
| 2010 Toyota Yaris OEM Radio | FPG | Items for Sale by private party | 2 | 07-05-2010 01:10 PM |
