Old 05-27-2007, 06:46 PM   #1
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
still haven't done mine, too lazy, probably wait til I get a replacement armrest, nice to see a pic of this no one has posted yet
what bulb did you use?
I have the one from autolumination but I am a little worried about it 'cuz violin said his burned out in just 5 months
SPONSORED BY
Old 05-27-2007, 07:48 PM   #2
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Im using the blue tri-power from autolumination to match the blue wedge LEDs for the A/C knobs. Works like a charm and looks great so far.
Old 05-27-2007, 08:07 PM   #3
brickhardmeat
Lonesome Cowboy
thats the one I have around here somewhere, hopefully it last a good while
SPONSORED BY
Old 05-28-2007, 09:09 PM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
How long have you been running yours?
Mine got a lot of hors in 5 months because I leave my lights on all the time... but still...
Old 05-29-2007, 10:12 AM   #5
redyaris
redyaris's Avatar
One month now...i use my lights conservatively and dont do much night driving so im crossing my fingers...I expect an LED to last years however.
Old 05-29-2007, 10:56 AM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I've had mine for roughly 5+months, works great (crosses fingers)... And I drive a lot at night + day driving with lights on..
will work for parts
Old 06-26-2007, 06:00 PM   #7
freshprince130
Drives: 2007 silver liftback
what size do you use to remove the bolt and does the light have that little green condom on it. I removed the ones of the ac controls and just left it white and am going to do the same to the gearshift light
freshprince130 is offline   Reply With Quote
Old 06-27-2007, 12:35 AM   #8
Jerkratt
Jerkratt's Avatar
its a 10mm i got this trim that goes around the outside of the shifter...so i did this. all tho i had to take my arm rest off first... my sig pic shows it lit up.. its real easy take bolt out, unscrew shift knob, there are 2 clips by the front. tug on the end and they pop out and then take your center consol and toss it to the side lol
EDIT: what type of LED is it. like is it a 194? wedge or something?
"It hurts more when its wet"
Old 06-30-2007, 10:44 AM   #9
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
yea what size led is this?
Old 06-30-2007, 10:54 AM   #10
redyaris
redyaris's Avatar
http://autolumination.com/74.htm
Its a #74 base. Its the tri-power (the first bulb listed on the site)...
This bulb is good because it spreads the light out from 3 sources.
Old 06-30-2007, 03:28 PM   #11
Jerkratt
Jerkratt's Avatar
thats the one i ordered when i get all my LED's ill doa little diy
Old 07-02-2007, 04:33 PM   #12
Jerkratt
Jerkratt's Avatar
ok so my wife woke me up saying u got a package... im like ok open it up and its the LED's so i get to work and
1. unscrewed the 10mm bolt in the cup holder (if you cant find the 10mm bolt then you most likely have an arm rest. take that off to show the bolt for info on installing/uninstalling factory armrest here)
2. took the little panel that holds my fog light and aux switches by the e-brake and tucked it threw the opening
3. with the car in neutral unscrew the shift knob (i have an aftermarket shift knob so i did not have to unscrew it before i took it off) lift from the back by the cup holder and pull the front up. there are 2 plastic clips by the front where the tray is to hold things you will hear the clips un cliping then put the center concole to the side
4. on the shifter there is a black plastic plate with the letters "P R N D 3 2 1" . remove this by uncliping the 4 tabs. 2 on each side take that off and the pull out the condomed bulb and replace with LED.
pictures asap my phone broke so i gotta get a digi waiting for mother in law to come home so i can use it
Old 07-11-2007, 12:03 AM   #13
Jerkratt
Jerkratt's Avatar
did this help?
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
Bulb sizes for all Yaris Models DJ_SpaRky Cosmetic Modifications (Exterior/Interior) 16 07-22-2009 10:23 PM
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 08:33 AM
bulb covers 90tsi Cosmetic Modifications (Exterior/Interior) 2 03-03-2007 01:18 AM
