#1 |
![]() ![]() Drives: 2008 yaris 3dr hatch Join Date: Jan 2014
replaced the SRS module. with a new one from dealer... didnt help at all... dont even know where to look for now!!!
#2 | |
Since the SRS ECU is new, and the wiring tested fine, if that is the correct code, then the pretensioner has to be the culprit. Before buying another one, you can connect a 3 ohm (make sure it is 3, not 3K ohm) in place of the pretensioner to verify.
#3 |
getting a 2.3 ohms on a seat belt.... the thing is ive tried 3 different seat belt, i know they are all good for sure! tried 3 different modules, including one brand new one, still getting 7 and 3 blinks!
#4 |
For the heck of it, check the connector under the driver's seat for the driver's seat belt buckle. That would be code "37".
#5 |
#6 |
It definitely is crazy. Check that connector now though, as you never know.
#7 |
checked evrything! i even replaced the passanger airbag and passanger seat with seatbelt just in case.. i know dealer will be no help to me cuz they got the standard operation procidure, and i did it all my self. maybe somebody here had the same problem and they have the solution?
#8 | |
Can you take a video of the light pattern?
#9 |
The floor or the dash harness?
#10 |
The floor one is the one that goes from the SRS ECU to the pretensioners. I really don't think that it is the harness though, with what I had you test.
I would really like to see the light pattern. If it would be easier for shooting it to me, I can PM you my cell or email to send it to. From there we can go through a step by step bit of testing to try to pinpoint the problem.
#11 |
I am on the edge of my seat. This is playing out like that Nicolas Cage movie National Treasure. I hope you find the answer, dude.
#12 |
here is the video! first i jump two pins to read the code (7 and 3 blinks) than i try to erase the code (two attempts) after which you can see when you turn the ignition off for about one second the light functions normal, but when its off for a little longer the light comes back on again with the same code!
http://www.youtube.com/watch?v=eA-asC2-C-s |
#13 | |
Have you perchance checked the driver's side one?
#14 |
thats the thing.. some service manual say its the right side some say its the left side, thats why i've tried both sides..right now i got the new floor wiring in it, new seats (both sides) new seat belts (both sides) new wheel bag, new passenger bag, new module, and a new front airbag sensors (both sides) the only thing i haven't replaced on that is the dash harness and the wires that go out to the front impact sensors. i am just clueless about this whole thing!
#15 | |
#16 |
i have a parts car so there is not much i spent so far except time and a new SRS ESU from dealer which was like 119$. it is a left (drivers side)
#17 | |
When I get back I will put together a set of instructions for what to do next.
#18 |
Out of curiosity, did your parts car have one or both of the airbags pop?
| The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) | Darb | Off-topic / Other Cars / Everything else Discussions | 86 | 10-18-2017 09:03 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 02:50 AM |
| full tank | japle | Fuel Economy Forum | 15 | 12-10-2013 12:05 PM |
