Old 02-12-2014, 09:33 PM   #19
rcvmini
Drives: 2009 Yaris HB
.....and the winner IS !!!!
16 inch MOMO RIMS
rcvmini is offline   Reply With Quote
Old 02-12-2014, 11:31 PM   #20
Radvr6t
Toyota Echo NOOB!
Radvr6t's Avatar
Drives: 2005 4dr Echo hatchback
post up a pic of the car
2005 Echo hatchback Project (Silver)
Instagram: Lawrencephotography
Radvr6t is offline   Reply With Quote
Old 02-13-2014, 01:09 AM   #21
rcvmini
here it is!
We fit them to make sure the bolt pattern worked. Noticed the lug nuts are small on the stock rims and sink deep into the new rim lug holes. Do I HAVE to buy new longer lug nuts?
Old 02-13-2014, 09:18 AM   #22
5 lug hubcaps Use those suckers for skeet shooting now!!!
That one Momo appears to be in pristine condition. Are the other 3 equally as nice?
Old 02-13-2014, 10:54 AM   #23
rcvmini
Hahaha yeah I didn't realize the 5 bolts on the caps till went to take off a tire.
Yes they were all in really good condition.bit 2 hav3 crub rash. Im going to plasti dip them black.
So do I need longer lug nuts? Also what size threads are they on the yaris?
Old 02-13-2014, 11:08 AM   #24
12x1.5. I would get this since the hole seems to be tight fit.
Old 02-13-2014, 05:19 PM   #25
rcvmini
Saw some nice metalic red ones but I have to order them Could I use the stock shorter ones in the mean time?
Old 02-13-2014, 07:02 PM   #26
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Pics please with wheels on the car...nice rims :)
Old 02-14-2014, 12:14 AM   #27
7:34pm
Drives: 07 Yaris
Those will look nice on the white car!
7:34pm is offline   Reply With Quote
Old 02-17-2014, 01:38 PM   #28
Radvr6t
Toyota Echo NOOB!
Radvr6t's Avatar
Vancouver local
Old 02-17-2014, 02:06 PM   #29
The depth of the wheel's lug nut holes doesn't matter. The key is to look at the shape of the surface that the lug nut touches and make sure that it is the same shape as the lug. So, if it has a taper (and the angle of the tapers match), you would use tapered lugnuts (which is what the OEM ones for the steelies are). Some alloy rims have really tight holes, where you can't fit the stock lugs with a wrench into. In that case you have to use smaller outer dimension lugs.
I NEED Boost... Opinions puh-lease Focus_Sh1ft Forced Induction Forum 551 02-08-2013 05:55 PM
Sway bar opinions Nelson Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 12-10-2008 06:40 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Need Opinions on Package Options bdc87 New YARIS Purchase Forum 8 06-26-2007 01:55 PM
Opinions on '07 Hyundai Accent hatch? Yaris Revenge Off-topic / Other Cars / Everything else Discussions 44 05-07-2007 11:18 PM
