Old 12-06-2016, 03:54 AM   #19
speed1
Drives: vitz rs
speed
Hi bro, u need higher top speed u ecu remap is last job.. I mean if u have n/a engine.. do u have 1.5 1nzfe? U need hi lift cams.. I can help..
speed1 is offline   Reply With Quote
Old 12-06-2016, 04:08 AM   #20
speed1
Drives: vitz rs
speed
u need your engine to make higher revs and so power.. if u put longer final without increasing engine performances u go bad acceleration and u need too much to reach same speed as now but worst probably u don't improve any speed..
Old 03-13-2017, 07:45 PM   #21
Majoto2
Drives: 2012 Red 3 Door Hatch Manual
Swapping ECM in America?
There are very many. For the US market alone there are over 20 separate part numbers. The variations for our market include different features (ABS, traction control, transmission type) and regional differences (US, Canada, Puerto Rico and Mexico specific ECMs).
2012 Yaris 3D hatchback manual.
Is is possible to swap out my Japanese ECM for an American/Canadian/Puerto Rican one so I it will then have cruise control in the ECM? I bought the car in America and it has a J (for japan) on the first slot of the VIN, I am assuming that the computer was built in japan and doesn't have these features built in.
But it makes sense in my head that if I found a manual ECM programmed in America then it would swap over without a hitch.
Can you help?
Majoto2 is offline   Reply With Quote
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
