Old 05-01-2014, 05:35 PM   #19
detroiter
detroiter's Avatar
I'm going to try uploading a video from the phone for an example.
Old 05-01-2014, 05:44 PM   #20
Rigaud
Drives: 2009 Yaris
It sounded great at WOT. I have the K&N Typhoon now.
As far as heat soak, any short-ram-style intake is going to likely suck in warm air. They're probably more of a noise maker than anything.
Most stock intakes are designed so well these days that it's unlikely any gains of more than 1-2 hp could be made if that unless you're already making serious power (e.g. Garm's old Yaris).
On a 1.5L engine you don't get more then maybe .5 h.p., better throttle response and noise. Whether a short-ram or a long cold air intake theirs no power gain really. Been a lot of studies and research on that and like you mention, their so well designed now. On bigger engines 5.0L and bigger theirs an increase.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 05-04-2014, 11:38 PM   #21
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
DONE! sounds better and seems to "lean burn" better too! Now I can't decide if my engine or exhaust is louder!
trunkout is offline   Reply With Quote
Old 06-24-2014, 11:11 PM   #22
adf_604
adf_604's Avatar
Drives: 2003 Echo Sedan, Silver
Thumbs up wish i'd seen this sooner
Sorry to revive an old thread but saw this mod recently and used it on my car just today. Worked great and also removed the so-called "elephant trunk" intake pipe, sounds pretty good!
thx to OP.
adf_604 is offline   Reply With Quote
Old 08-11-2014, 11:02 AM   #23
driverofchuckles
driverofchuckles's Avatar
Drives: 2008 Yaris. Manual everything
Originally Posted by detroiter View Post
Here's basically what I did...goes all the way around the lower portion of the intake box
Getting ready to drill this exact moment!
driverofchuckles is offline   Reply With Quote
Old 10-19-2016, 10:35 AM   #24
David C
Drives: White '07 3dr LB
Did mine too and I did remove the neg from the battery for over a minute to reset the ECU, and since then I've noticed the car would reach higher RPM on strong acceleration before shifting gear (automatic transmission) that it did before. Looking at my fuel gauge (I filled up right after doing the mod), it seems I'm getting very poor mileage so far, but it could be due to many other factors, like the gas station auto-stop fuelling setting, the colder weather that just started (thus using the PTC heater more and blower fan more), etc. Perhaps the ECU needs more time to recalibrate with the air/fuel flow during fast acceleration. I would reach 4 000rpm easily from a dead stop before first first while before it wouldn't go beyond 3 500 rpm. Good/bad ?
David C is offline   Reply With Quote
Old 10-20-2016, 01:07 PM   #25
jcboy
Drives: Sedan 07
I believe the fuel ratio is maintained by the ecu so if you are feeding more air, your fuel consumption will also suffer.
Sent from my G9208SS using Tapatalk
Old 10-20-2016, 04:01 PM   #26
fwiw I have a short ram (modified my TRD CAI) and to aid in the heat soak I used 3" plastic heater ducting and cut a hole in my fog light cowling and ran the ducting up into the engine bay where it ends right at the air filter. The ducting it zip tied in 2 spot on the cowling and one spot in the engine bay
This won't do much when stopped but once moving air is forced into the ducting and flows out over the filter and essentially gets rid of heat soak.
I don't have any dyno's to compare but it cost me $5 and about 15 mins to do. Also doesn't look too bad either.
Stock Injectors = Maybe? Big NO? maxthehax Forced Induction Forum 3 12-10-2012 05:29 PM
HELP need STOCK wiring harness for stock deck ya_RS Canada 0 09-26-2010 05:50 PM
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 08:45 PM
STOCK SEATS OUT OF HB / stock tires/rims mrrock Items for Sale by private party 19 08-19-2009 04:56 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 04:19 PM
