Old 05-30-2006, 02:52 PM   #19
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
Posted pics on first page
pennystocks is offline   Reply With Quote
Old 05-30-2006, 05:15 PM   #20
birdy
I stay G'd Up
birdy's Avatar
Drives: 02 wrx wagon
Send a message via AIM to birdy
how hard was the install? for a person with auto knowledge? I have installed turbo kits flawlessly so I know my way around cars. is it like plug and play or is there any wire cutting and splicing..
birdy is offline   Reply With Quote
Old 05-30-2006, 09:58 PM   #21
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
It plugs into the OBDII diagnostic connector under the dash...This powers it, so no additional wires needed....
Cheers
echo_hrs is offline   Reply With Quote
Old 05-31-2006, 12:04 AM   #22
pennystocks
Yea, easy install, i just took the panels by the radio off and ran the wire to infront of the gauge cluster.
Old 05-31-2006, 12:40 AM   #23
birdy
I stay G'd Up
birdy's Avatar
sweet thats good to hear
Old 06-04-2006, 11:31 AM   #24
jah
jah's Avatar
Drives: Hatch
Got mine, very cool! For now I have just ran the cable under the steering wheel into the drivers glove-compartment. Here is a pic, I just open the glove-compartment when I want to see the RPM/WaterTemp/Mpg, etc
If the glove-compartment door isn't real expensive, I might order another one, and cut a hole out, then mount it to the door itself
jah is offline   Reply With Quote
Old 07-08-2006, 11:33 PM   #25
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
i'm wondering how much the driver compartment door will be too, i'd like to mount my tach in it and i plan on also buying a scangauge2...
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 07-09-2006, 11:41 PM   #26
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
Awesome! Thanks for the Write-up on the Scangauge unit!!! I'm gonnna have to get me one of those. Does the MPG seem correct after a few tanks of gas?? do you end up filling up with the same amount as it states you use?
THANKS AGAIN!!
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 07-10-2006, 07:22 PM   #27
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
THANKS AGAIN!!
I have a scanguage II and its amazing! I asked about the mpg in another thread and I believe its fairly correct...there's instructions in the booklet on how to set up the device for mpg...you have to put in your engine size, size of tank and go to the fill-up section and push done everytime you fill up. It tells you miles you driven, average mph, max rpm just driven and so on.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
