Old 04-19-2007, 03:55 PM   #19
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
I'm not very clear on how "more spark" is supposed to help combustion any? If you have a bucket of gasoline, it's gonna blow up the same... doesn't matter if you use a torch or a match to set it off. Can someone explain?
your best bet is too look on nology's website they have a pretty informative Q&A section basically though your right you can light a pool of gas with a match but have you tried, it actually take a little bit of time for the pool to light, it takes less time with a torch. The same general rule applies.
So what are the plans for the new motor?
well basically no one makes any internals for our engine. Some companies have made custom parts for it, basically though I am going with a fully built engine so it can take some high levels of boost. I'm going for fastest street Yaris in the country. I like being on the forefront and developing new parts. Expect a lot of updates on the engine build as I get more and more of the info about our engines. Custom internals take a lot of work esp piston design and cam design.
The re-route looks great. And you making me more and more jealous with your setup. Stop upgrading already!!! Seriously though, nice work.
sorry i'm a car guy I can never stop tinkering or upgrading. I have two projects in the works already that will hopefully be done or nearing completion soon. The one is the intake/manifold, soon I will post side by side pics of the throttle bodies its quite amusing how small our TB's are. The other is some aero work, with an aluminum underpanel, and maybe some underbracing. I will keep you posted.
And yes it is a lot of work, but personally I feel it is worth it because If i have to show off my engine bay I want it to look nice and clean, plus I am still trying to go for that sleeper look so I wanted it to look semi stock. I haven't been able to dyno the difference, I will get on the dyno soon but it wont be able to give you good before and after dyno results becuase the numbers will be from different conditions.
The only thing to inform you guys about, I'm told that the nology wires will work fine on a stock setup, but just so you guys know, I was able to finally get on it (since I live in the city I havent been able to) I have a miss at the top of 2nd and 3rd gear. I know this is because with the stock ignition system my tune required the timing to be adjusted and now it only needs adjusting again because the way the wires perform. I don't believe you guys should have to adjust your timing at all because the ecu will probably compensate for it, however since my ignition is set, it needs some further adjustment. Just so you guys are aware of the situation.
turboyaris is offline   Reply With Quote
Old 04-19-2007, 04:21 PM   #20
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Can't wait to hear more.
Galavoxx is offline   Reply With Quote
Old 04-19-2007, 05:22 PM   #21
joey1320
joey1320's Avatar
Drives: Yaris LB
well there are aftermarket performance rods/pistons. you can get them here:
http://www.raceeng.com/searchadv.asp...=21&submit.y=9
i have bougth from race eng. and they are great.
awesome customer service and attention to details. good luck.
i can't wait to pick up an extra engine.
Old 04-19-2007, 05:30 PM   #22
turboyaris
thanks for the link the crower rods I was probably going to go with, I might change up some of the specs though haven't fully decided as for the pistons, I am having the block sleeved so I want more then just .5 mm overbore you know. but thats definatly helpful for the people that just want to purchase off the shelf and don't want the hassle of custom work. ZPI also has rods and pistons on their site. Just for fyi for you guys.
Old 04-19-2007, 05:49 PM   #23
joey1320
joey1320's Avatar
Drives: Yaris LB
cool man. definitely keep us updated on the build. i will go with stock bore or maybe .5mm over. i never like to take metal away from the cyl. walls if i don't have to, so just a honing' job will be used.
plus the fact that you put down over 180whp with a stock engine, i know with these parts i could easily get over 220whp which is what i'm shooting for.
Old 04-19-2007, 06:01 PM   #24
turboyaris
on their scion xb zpi actually upped the boost to 12 psi and had about 230 to the wheels but with slicks, the snapped the axles. They said the engine held fine, now for how long is another story. I am shooting for a decent amount higher then 220 to the wheels. but yea a stock bore with beefier components would definately allow for 220 to the wheels. just be careful with our tiny axles. and taking metal away isnt too bad if like i am doing you sleeve it. it allows for a bigger bore, i'm hoping to be able to get a couple mm over bore, maybe have a 1.6 liter engine haha.
Old 04-19-2007, 06:18 PM   #25
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i have ran into this one!!
http://iwcweb.com/eclipse/html/warning.html
Old 04-20-2007, 09:39 AM   #26
joey1320
joey1320's Avatar
Drives: Yaris LB
nice to know that zpi got those numbers. and if you are gonna sleeve the block then you should be more than ok to bore it. i just wanna keep the stock sleeves and replace the rods/pistons, headgasket and head bolts.
i'm not sure if i wanna do anything with the head, if any i'll just replace the valvetrain with stock size/angle units and go from there. i don't like messing with the original equipment. i just like to make it stronger.
good luck!
Old 04-22-2007, 08:38 PM   #27
turboyaris
alright guys just to clear it up, I regapped my spark plugs down to .035 instead of the stock .044 as I was advised to do by nology and now... no more misfires at high rpms. Just to clear that up, I was pretty sure that was the problem.
Old 05-14-2015, 01:16 PM   #28
jiovanny
Drives: yaris sport 2008
good afternoon people, great forum, I write from venezuela, I wanted to know more information about the post: cables are? What are the coils? in that I help? If you improve performance?
Thank you very much in advance:burnrubber:
jiovanny is offline   Reply With Quote
Old 05-14-2015, 01:17 PM   #29
jiovanny
