Old 04-23-2007, 05:49 AM   #19
spkrman
Drives: 1
There's no master document that shows it but it's in every white paper on the ECU that's bundled with our 1NZ-FE engine.
It's also in the white papers for the ECU that's bundled with the 1.3L engine (same ECU, slightly different programming).
Those are the only 2 engines the Yaris comes with no matter where in the world you are, so every Yaris has DFCO.
diesel? There is also a 1.0l isnt there?
Old 04-23-2007, 10:35 AM   #20
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Originally Posted by nebulight View Post
This post is pissing me off! I've tried to drive in the lower RPMs, turning off my car at lights, pumping up my tires to 50psi, DFCO, turning the car off while going downhill, you name it. And the best I was able to get was 37mpg on the highway, and I just filled up today and got 34mpg city!! What am I doing wrong?!
My driving is about 50/50 (town/interstate) and I have never had mpg that low? I do drive with real gentle input to the throttle and keep my speed at approximately 65 mph on the big road. My average is 43 mpg.
Do you have a bunch of extra stuff (weight) in the car? Do you accelerate briskly from stops? Are you using cheap (no name) fuel? Has the car been properly serviced?
blacksan is offline   Reply With Quote
Old 04-23-2007, 10:48 AM   #21
Sabina74
Yaris Lover!!!
Drives: Yaris 1.0 Sol 5 doors liftback
Send a message via MSN to Sabina74
WOW! that's incredible!
with my 1.0L i get 40 mpg!!! i thought it was good...!!!
Sabina74 is offline   Reply With Quote
Old 04-23-2007, 11:32 AM   #22
that was what i was thinking, but i wasn't sure if this gen Yaris is available with that motor.
Old 04-26-2007, 07:03 AM   #23
Edd
Drives: None
Just for confirmation, can you provide me the info saying that all Yarii have DFCO?
I thought all cars made in the last 5-10 years had that. Either way, are you really prepared to shut off power steering and braking just to save a few litres of petrol? Not to mention that "coasting" doesn't last forever and the car slows down... Unless you mean taking the car down a hill where no throttle is required - in which case it would be crazy to lose half the safety features of the car by turning it off.
Edd is offline   Reply With Quote
Old 04-26-2007, 03:05 PM   #24
BailOut
Steals terrorist's lunch
BailOut's Avatar
Again, I ask that each of you be careful with the (dis)information that you spread.
The Yaris is drive-by-wire. As such, with the engine off and the key in the Ignition II position you still have power steering. The vehicle's brake system also has enough vacuum to support a minimum of 4 brake touches (uses) before it starts to deplete the power assist.
This means that performing a FAS (coasting in neutral with the engine off) in the Yaris is perfectly safe as long as you remember to re-engage the engine after a few friction brake uses in order to regenerate the vacuum.
While "coasting doesn't last forever" neither does any other form of movement, so I'm not sure what your point is.
- Brian
Share the Road
Old 04-26-2007, 03:25 PM   #25
nope, won't ever shut off my car while driving. rather have safety than save a few mpg.
Old 04-26-2007, 06:18 PM   #26
Edd
Drives: None
Oh, sorry KL, I misinterpreted what you said.
Old 04-26-2007, 07:54 PM   #27
BailOut
BailOut's Avatar
Again, if you still have forward momentum, you still have power brakes, you still have power steering and you still have airbags, etc., then exactly what safety do you think you give up by turning the engine off and then putting the ignition switch back to the Ignition II position for a coasting segment?
- Brian
Share the Road
Old 04-26-2007, 10:17 PM   #28
yeah, i know that if it's on the "Ignition II" position, then everything but the engine should be on, but it's just me...but yeah, when does it apply that if a car is moved more than 50 ft and the engine is not on, then damage could occur to the cat?
Old 04-26-2007, 10:17 PM   #29
it's all good.
Old 04-26-2007, 10:22 PM   #30
ChinoCharles
Drives: LB
Ever been in an event where you had to speed up to avoid an accident?
Preach that FAS crap on CleanMPG. No hard feelings, but seriously, there are some battles you hypermilers just won't win here. That is DEFINITELY one of them.
Old 04-26-2007, 10:30 PM   #31
oh yeah, there are some hella stupid ass drivers here in Sac. i can have my turn signal on for at least 5 seconds and have started switching lanes, and some of these stupid mofos here speed up and start honking there horn. and the stupid thing is, they were at least 3 car-lengths back...
Old 04-27-2007, 03:23 AM   #32
BailOut
BailOut's Avatar
Nope. Not once in over 20 years of driving on 4 continents.
Such is the power of defensive and anticipatory driving.
- Brian
Share the Road
Old 04-27-2007, 03:26 AM   #33
Black Yaris
der Zeck
Black Yaris's Avatar
Damn dude, with driving skills like that you gotta have the ladies all over you
Old 04-27-2007, 03:32 AM   #34
ChinoCharles
Drives: LB
Ohh, so you can see things before they happen, eh Bailout?
I hope Grandma doesn't pass out at the wheel behind you while you're rolling down a hill.
Old 04-27-2007, 03:40 AM   #35
Black Yaris
der Zeck
get it right Chino, He drives a Yaris, don't you ever watch this show
Old 04-27-2007, 08:31 AM   #36
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
okay, i just filled up after my Santa Cruz trip, and calculated my mpg. i got 48.57 mpg! most of that was freeway driving, but i was averaging 70 mph, hit stop and go traffic on the way out, and using the A/C. parts of the trip was downhill, so i was cruising that part in neutral. but man, that's some good mpg. lol...the best i've ever done was 50 mpg.
Chk this out:
http://news.rgj.com/apps/pbcs.dll/ar...704150326/1247
ricepower is offline   Reply With Quote
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 09:15 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 11:49 AM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 11:07 PM
Rims, Tires, and MPG Pavel Olavich Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-23-2007 08:28 PM
Yaris Mpg query Vanguard General Yaris / Vitz Discussion 3 03-18-2007 10:56 AM
