Old 08-06-2015, 05:12 PM   #19
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Some info if you considered the Prius Piston Swap:
- Take a notch from the top of each piston due to some knocking in the yaris who had my prius pistons, other than that you just open, drop them in and run it
- 13.1:1 compression! Like always your gains come from doing changes and or multiple mods. Open up exhaust, intake, bigger throttle body, port intake.Need fuel management too at this point to tune. From what I know and believe you don't require bigger injectors but a tune at a dyno would determine that. Some have shown gains with dyno numbers at 132whp so around 145hk at the crank. No turbo.
- Tune with something like the AEM FIC, Greddy eManage, APEXI Neo, etc.
Some videos of a car equipped with the swap:
Angelos Prius Piston swapped Yaris
Old 08-07-2015, 09:41 AM   #20
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
this is tempting also....
When you say "notch", what is suppose to be notched to avoid damage to what?
-Derrick-
Old 08-07-2015, 09:47 AM   #21
fnkngrv
fnkngrv's Avatar
Not really sure unfortunately.
Sent from my SCH-I545 using Tapatalk
Old 08-28-2015, 08:40 PM   #22
tempest404
Drives: white 2015 1.5L yaris
When it comes down to the running though do i need to go aftermarket with the ecu? Or is the stock one viable?
Eyeing up an exhaust system atm
tempest404 is offline   Reply With Quote
Old 08-29-2015, 01:43 PM   #23
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
To take advantage of the full Prius pistons compression you'll probably need a progamable aftermarket ECU. Maybe you can get away with using the stock one, but don't expect the same gains.
Someone is selling their Haltech here: http://www.yarisworld.com/forums/showthread.php?t=54910
If you plan on keeping the 1NZ engine, i'd also suggest looking into lightweight pulleys or even a flywheel. It might not make any HP but it will certainly help with acceleration and help make the car "feel" faster.
Old 08-29-2015, 01:54 PM   #24
fnkngrv
fnkngrv's Avatar
Prius pistons will require a piggyback otherwise you are throwing money out the door.
Old 08-31-2015, 01:57 PM   #25
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
When I built my last motor I bought a Prius Piston from a Prius C 13.4:1cr just to see how it compared to the Yaris parts.
You don't need to notch the piston, but there are a few thing you up running into. The intake cam will go from being a non interference part to a interference part, so you'll be limited to the cams you can run, and its very likely you'll need to run 93+ octane fuel.
2014 BSpec Divisional Champion
turbo supercharger kits
