Old 10-26-2015, 01:02 PM   #19
Jason@SportsCar
Originally Posted by Rednaz View Post
Guys..a concern I have is braking power. What brake setup can I run to retain my 15 inch rims but still have decent stopping power for the BEAMS?
Factory brakes are more than adequate, just upgrade the pads. And upgrading does not mean using cheap EBC pads, put a real performance pad on there. We have Hawk DTC-60 custom cut to fit our calipers.
Old 10-26-2015, 01:41 PM   #20
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
If you have a real concern you can put the SE brakes on the car, but I don't think its an issue. I've had to stop the car from 120-50mph, and never had an issue with overheating or the cars inability to stop.
2014 BSpec Divisional Champion
Old 10-26-2015, 04:38 PM   #21
Rednaz
Drives: 2006 Yaris 1300
@Jason:So the Hawk DTC-60's we be more than enough to stop a 200hp car? Sorry if it seems like a noob question regarding braking. @xnameraxx: what are SE brakes?
Rednaz is offline   Reply With Quote
Old 10-26-2015, 05:21 PM   #22
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have upgraded to carbon pads and upgraded rotors, but that is bwcause I have to decel from over 150mph to 40mph in an 1/8th mile. They have served me well so far. I have left the stock rear drums on. Actually with the heavy braking and regular driving amazingly I still have the original shoes and drums with 100k on the chassis. As Jason said the stock setup is pretty robust. 200whp can be handled fine unless you REALLY put the screws to them. As for engine mounts excetera that Garmin was running yes he did indeed upgrade to ttr dumont once he jumped up over the 270 whp mark. And mainly you have to do so because at that point you're running at least 15 pounds of boost in most setups.
Sent from my SCH-I545 using Tapatalk
Old 10-26-2015, 07:34 PM   #23
Jason@SportsCar
130mpg+ down to 50ish mph, repeat for 14 laps.
http://www.scca.com/videos/1972494
OE rotors, Micro Image brake lines, Hawk DTC-60 pads from Porterfield Brakes. Still look like new. I replace the pads and rotors right before the Runoffs each year, and typically the old ones are still not used up.
The power level of the car is of little significance, its what you do with it.
Old 10-27-2015, 08:51 AM   #24
Rednaz
Thanks Jason!
beams, redtop, toyota
Low beams & High beams on together? Deathegg DIY / Maintenance / Service 26 12-22-2018 10:19 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
