#1 |
Check the ALT-S fuse. If it is bad, the alternator will not turn on and you will just run off battery power.
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
rider99 based on the electrical damage to the car. perhaps its not a bad idea that you get checked out too. You weren't grounded any more than the car was.
And while you may be feeling fine, your calcium and potassium are likely out of balance which could mean trouble in a few days. |
#3 | |
In a car is about the safest place you can be when lightening strikes. Lightening is only an issue for the human body if it finds its path to ground through you. I have been on many an airplane that has actually been struck directly by lightening.
#4 |
![]() Drives: 2007 yaris sedan Join Date: Jul 2011
Another thing I did not mention is the idle is higher than normal
#5 |
Alt fuse good
#6 |
ALT-S?
If so, you may be looking at a damaged voltage regulator within the alternator.
#7 |
Yes alt_s
#8 |
Just an update sent to dealer 3800 repair bill thank goodness for comprehensive and small deductibles
