#1 |
![]() Drives: bmw x5 Join Date: Apr 2015
has been bookmark, this seems like a very interesting thread
In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
2006 hatchback. 368000km 229000 miles, still on OEM clutch, starting to shudder in first gear and disengagement a little hard from 3 to 4. Have to change the transmission fluid at 380000. So i'll change the clutch then.
#3 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
I'm on the original with no issues, 171,600 miles.
It's not so much about mileage but the ratio of city/highway, driving style, etc. If you commute in gridlock an hour each way in Los Angeles, DC, or Manhatten, your clutch is going to have a relatively short life. On the other hand, we've seen Yaris's go 300, 350K on the original clutch with like 80% highway driving. |
#4 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Half the time, I don't even use the clutch while getting up to speed on the highway. |
#5 |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
#6 | |
![]() ![]() Drives: 08 Yaris hatch Join Date: Oct 2015
Sent from my XT1254 using Tapatalk |
#7 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
2007 Sedan
miles: pulled at around 45k miles I upgraded to the CCI Stage 3 clutch and ultra lightweight flywheel combo. For a long time it was one of my best investments other than going turbo. Last fall during my speed runs I pretty much did a lot of stress damage to the pressure plate apparently because about 6 weeks later I had 3 of the 5 springs let go on it (25k miles on the setup). I would never buy another CCI product again personally. I contacted them because they stated that the clutch assembly should hold up to 300whp/280tq. I was running 250/245 and yet the pressure plate broke. I don't hoon on the car nor do I do things like auto x, etc. I asked them to meet me in the middle on a replacement and they flat our refused. This was the straw that broke the camel's back. I can prove via dyno results where my power was at and my logs on my EMS can show that I didn't over rev nor abuse the clutch. The first issue that I had with them was that they claim to have payouts for setting records and winning races. I sent them my information back in 2012 when I set 6 new records. They informed me that Land Speed Racing isn't well enough known for a payout?!?!? Last time I checked Bonneville Speed Week is a pretty big deal, but whatever makes them sleep at night. I upgraded to a Stage 3 setup from ACT this time around. It is their best and highest rated kit for street/track use. It is a 6 puck, but I have been told by a few very good sources that have them equipped on their 1nz that it is a very usage scenario for DD so we shall see in a couple months when the car is buttoned back up.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#8 |
Just recently started trying to rev match while down shifting but with no tach and a stereo that drowns out any sounds from the car its a lil difficult, but I feel like I'm getting the hang of it, just wanna get some wider pedals cuz the stock ones are tiny
#9 |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
To add my experience:
Replaced the OE clutch at 70,000km. Clutch still had probably 60-70% material, but some pressure-plate springs were soft (Clutch height was erratic). The release-bearing also was wearing through the springs pretty bad. I do a fair bit of autoX with the car, and drive on R-comps for several months a year. Pretty hard on things. The OE clutch is VERY sturdy built. Don't worry about a little slipping, or the occasional jerky engagement; It won't hurt it at all. Toyota built these clutches to last. The flip side is they are heavy. I installed a LUK kit which was a fair bit lighter (and will not last nearly as long). The lighter weight allows a small, but noticeable difference in acceleration. Pedal feel is similar (poor) with maybe 10% more effort required than the OE clutch. |
#10 |
![]() Drives: 2010 3dr Yaris Join Date: Oct 2010
2010 bought new, now has 222k miles on clutch. Only problems has been rear wheel bearings.
#11 |
![]() ![]() Drives: 2010 Yaris hatch Join Date: Mar 2011
2010 three door, bought with 6000 milea in 2011. Now a bit over 70k, no issues as far as I know. But I'll tell ya - next car if I stay in SoCal will be an auto.
"I like the dreams of the future better than the history of the past" - Patrick Henry |
#12 |
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
I'm the original owner of my 2010 hatchback.....bought it right at 6 years ago (Nov. 2009). It has 123k miles and still has the original clutch, which is functioning just fine. Most miles are highway......probably a 60/40 highway/city split.
| Getting Rid of the infamous Clutch "Shudder" | tmontague | DIY / Maintenance / Service | 14 | 07-08-2023 01:56 PM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
