Old 10-28-2015, 02:32 AM   #1
Vitz_Q8
Vitz_Q8's Avatar
Drives: 3dr NCP90R
Sorry guys. I've been very busy these days hopefully it will be done by next week. for the minimum number of preorders required I'm not sure tbh. I'll contact PG and tell them to post in this thread just to give a more "official" that PG are behind this not some unknown guy posting on the internet.
You can see in the attachments the difference between the rear and front wheels my wheels are 15x7 +35
pictures in order are F-passenger>R-driver>F-driver>R-passenger
Vitz_Q8 is offline   Reply With Quote
Old 10-28-2015, 08:47 AM   #2
aspro
Originally Posted by enviri View Post
i have 10mm spacers i took off a long time ago, since they dont work with rear disc brakes.. i dont have any bolts or anything, just the spacer itself.
Pm sent
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 10-28-2015, 08:52 AM   #3
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
I already have a set on my Yaris, otherwise i'd totally be interested.
I wish you guys good luck though.
Black_griffin6 is offline   Reply With Quote
Old 10-28-2015, 10:58 AM   #4
ITA
Drives: 2001 Echo Sedan
Sorry, I will have to retract my request. For some reason I thought these would work with my 2001 Echo. I didn't realize its only for the Yaris/xD. Sorry about that!
ITA is offline   Reply With Quote
Old 11-03-2015, 02:22 PM   #5
aspro
Remove me from the list. I couldnt wait for PG so i bought a used pair from a member. Thanks and good luck with this!
Old 11-03-2015, 02:24 PM   #6
aspro
Hopefully i can find some time and install it quickly. I will post before and after pics to help those who are looking to do this.
Old 11-03-2015, 09:03 PM   #7
aspro
I installed the 10mm spacers i bought used off of exiwolfman. Super easy install, had to put some elbow grease into removing the hub but she came out pretty easily on both sides. The 10 mm spacers i think are peeeerfect for my rim size (15×6.5 with 38 offset) worthy mod. Car feels more predictable when entering into the corner, just feels like there is more feedback and body roll has been reduced thanks to the wider stance. No rubbing so far and it looks awesome!
Driver side:
Passenger side:
Forgot to take before pics, i was too excited.
Enjoy!
Old 11-03-2015, 09:14 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Driver side:
Passenger side:
Enjoy!
Looks good glad u like the spacers ...i was to lazy to do it lol plus my 07 is little more crusty and would need new hubs with install.
Old 11-03-2015, 10:32 PM   #9
aspro
Thanks! Well, my buddy helped me big time. He has a lift and almost every tool you could imagine. Which made things a lot easier.
Old 11-04-2015, 08:03 AM   #10
No rubbing so far
Hit any dips yet on the 401 at speed?
I had to introduce camber washers when I was running 10mm spacers on 16x7 et 42 with 195 rubber to eliminate rear fender buzzing.
Old 11-04-2015, 08:08 AM   #11
aspro
Yes i have. And a few good sized pot holes. This set up will not rub... It is perfectly set.
Old 11-04-2015, 01:29 PM   #12
That is the exact same setup I want to run. Thanks for the pics and info regarding your set up. It's good to know it won't rub. I want to improve the stance but not have the headaches of rubbing tires. Just waiting to hear back from a member if he still has a set of spacers lying around.
Any updates on this group buy?
Old 11-09-2015, 02:03 PM   #13
aspro
A little update. I had my car loaded with myself and 3 buddies. Avg weight per person was between 180 to 220 lbs, i.e the car was slammed to the ground. I had some light rubbing on the inside of the fender on The passenger side only when i hit big bumps. So im cool with that but i think a fender roll would cure that as it is touching by about 1 mm. But im not going to even bother with that.
Old 11-09-2015, 03:07 PM   #14
appreciate the update. That's not too bad with all that weight in your car. I don't plan on ever running that much weight in my Yaris. I have 10mm spacers I'm installing tomorrow with camber washers. They should pair nicely with my new rims that I'll put on next spring, they're 15x6.5 and +35 offset. I'll likely need to use the camber washers since my rims are 3mm wider than yours.
Please remove me from this group buy, I was able to pick up a pair of wahsers from "Muskoka" who was great enough to dig them up from his basement for me!
Old 11-10-2015, 01:11 PM   #15
Aspro, how'd you remove the hubs from the axle once the 4 bolts were removed?
I am trying to install mine now and they're stuck on tight
Old 11-10-2015, 01:31 PM   #16
Put your wheel back on and kick the crap out of the tire. Should eventually crack the union between hub and axle.
Old 11-10-2015, 01:53 PM   #17
aspro
I used an air chizel and a prybar. If you dont have that then do what weeyari suggested. The weight of the wheel will help get some force generated and a good leverage point. Just be careful you dont ruin your hubs! And good luck!
Old 11-10-2015, 02:04 PM   #18
aspro
Oh and drop some locktite around both sides of the spacer and around the threads of the new bolts before you bundle everything back up. I also took the time to clean up the brakes as well since i was in there. And be careful with the abs sensor it was a big pain in my ass when trying to seperate the plug. Clean those out as well before you reconnect. Just some preventative stuff that goes a long way.
hub spacers, penguin garage, scion xd, vitz, yaris
