#19 |
Actually I have little pain unless I overdo it. Then...look out!
Taking meds to control pain...not good.
Synthetic Oil: Its All In Your Head |
#20 |
Agree.
Glad your pain isn't troublesome as long as you take care. Many not so fortunate. |
#21 |
Got one of the Yaris plugs out this AM. Didn't need the cheater pipe on the ratchet it came right out. Im going to clean the threads with gas and a toothbrush and reinstall it and run to the store for some anti seize later on. The gap measures 044 same as the plug for the Camry. Is this right?
In the picture note how the brown deposits are darkest near the end and get lighter as you move farther away. Since the sparkplug socket comes of the end of the 6 inch extension when reinstalling the plugs I shoo gooed the socket and extension together to prevent that.
Synthetic Oil: Its All In Your Head Last edited by bronsin; 12-09-2015 at 08:08 AM. |
#22 |
I carefully drop the plug into the hole with needle nose pliers and then use a regular socket (⅝ I think?) to tighten it up.
#23 |
That would work. The rubber insert of a standard sparkplug socket can also be lubed with a shot of WD40 so it doesn't grab the plug so tight. But it will still pull the socket off the extension sometimes.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
When my sparkplug socket falls off my extension I just use my magnetic wand tool and pull it out. Obviously this won't work if the socket is still attached to the plug. You can usually insert the extender back into the socket and jiggle it so that it comes off of the plug and then use the magnet to remove it.
#25 |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
You need better tools! I use a spark plug socket on a extension. with a dab of anti
seize on the threads. I have never needed to lube the socket. WD40 is not a real lubricant. It's water displacement (WD) formula 40. It's was designed to air dry and protect from rust. Yes. it does have some lubricating properties. Good for guns for long term storage not so good for long term lube. |
#26 |
Looks like my brother in law is going to get the job of replacing the plugs in the wifes Camry. He has his own repair business specializing in BMWs. I think the plugs can be removed just by torqueing them out using whatever force necessary. Not that I have the ability to do that. Besides if the threads come out he can do the fix.
Im wondering if he will try to get them out and agree with me its best to leave them in there?
#27 |
![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
Pb blaster is your friend here.I'm gonna change the plugs in my 2015 at maybe 50,000,hopefully I'll catch them before they stick.
#28 |
At 41k on my 09 Yaris they came out easy enough.
#29 |
the trick to starting plugs is a piece of vacuum or fuel hose.fit tight on the plug and just drop it in the plug hole.it kinda self aligns and starts.
#30 |
![]() ![]() Drives: Yaris 3-door Join Date: Aug 2009
Run the engine to operating temp, remove the coil & soak the plug with Kroil after loosening it. Work the plug back & forth. I doubt it strips. If it does, you can Time-sert it. If you don't want to Time-set it yourself, take it to a local machine shop & they'll do it on the car for about $50-$80. Never use Heli-coil, use only Time-sert.
#31 |
Ive r and r ed all the plugs in my 09 Yaris, cleaned the deposits off with solvent and a bristle brush and lubed them with copper antiseize and checked the gaps (they were good). In another 30k miles I'll r and r them again and relube to keep them from seizeing as well as check the gaps. I don't plan to ever change them but then again at 3000 miles a year in 20 years that'll be 60k miles and I wont need a car anymore anyways.
That leaves the wifes Camrys plugs. They've never been out at 126k and are stuck. Or at least #1 is. (didn't check the others) My brother in law is going to get that job. But if somehow he doesn't do it I might try all the suggestions myself. (ie warm the engine, loosen the plugs, douse with PB or Croil and turn them out. I figger about six months start to finish.
#32 |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
Bronsin, you are everywhere.. saw your name on a diesel thread... 3bt? 4bt? Or 7.3L? Anyway I changed mine on the Yaris at 75K replaced with BOSCHs with anti-seize as always! I anti seize my lug nuts too..
EDIT: BOSCH PUGS NOT NGK!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) Last edited by BIGTAZ351; 02-02-2016 at 05:23 PM. |
#33 | |
Under NJ laws it didn't have to be inspected but I found out the cops were using old vehicles as cash cows writing tickets for $$$ for various defects so I had to sell it.One thing about antiseize on lug nuts is it can change the torque readings ie you over do the torque. I find if you have hubcaps or acorn lung nuts theres seldom a problem. A shot of WD40 on the tightened open type nuts also helps.
#34 |
This is very true. I found out the hard way a long time ago and broke two studs. The nut felt like it was tightening up to 75ft/lbs then went loose and then POP! |
#35 |
If I remember correctly; When using Never Seize reduce torque by 10%.
#36 | |
Iridium Sparkplugs Experiment
Really? Never heard of that. I don't buy it. Torque would be measured by the resistance between contact surfaces, not how slippery the threads are. Sent from my iPhone using Tapatalk
| FS: Denso Iridium POWER plugs NIB | "G" | Items for Sale by private party | 60 | 03-22-2013 08:11 PM |
| ngk iridium ix - anyone got them? | GianniVRS | Performance Modifications | 2 | 11-12-2012 03:02 PM |
| So You Just Have To Have Iridium Spark Plugs eh? | bronsin | General Yaris / Vitz Discussion | 32 | 04-17-2012 02:14 PM |
| Where can I get iridium spark plugs??? | fidgell | Canada | 4 | 03-01-2010 12:10 AM |
| Sparkplugs? | nsmitchell | General Yaris / Vitz Discussion | 23 | 07-09-2007 06:47 AM |
