#19 | |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
**EDIT** Here's my spreadsheet for comparing the pinouts of the Yaris and xD ECU connectors. I will have to look at the EWDs again when I get home at the end of the month to see what the missing/conflicting names go to. Hopefully that connector just needs to be pin swapped. Last edited by CrankyOldMan; 01-15-2016 at 05:49 PM. Reason: Added link |
#20 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
The U340E is the automatic transmission in all yaris'. The 2zr harness has the exact same transmission plugs with the same wire locations.
The BAR station that inspects your car after completing the swap will give you a label to signify your swap is legal, the different VIN in the ECM is ok, the requirement is the cats have to be there, a legal intake, and no check engine light. |
#21 | |
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
I've got to go this weekend to get emissions done on my cars, my birthday is coming up, so got to get tags. I've got a buddy who I go to for emissions testing, I'll propose that question to him, to see if that's how it's done here in GA. |
#22 |
Data doesn't lie
Here is the xd engine mount PN#12305-37091....the associated bracket on the engine timing cover also has to be from a xd PN#12315-37040. You will also need the 2 bolts PN#91552-L1240, stud, and 2 nuts that attach the mount to the bracket. My engine came with the Corolla bracket and I wanted to test fit with it......it does not work.
Also you will notice the Corolla ECM back there. Ive already completed a swap with all of the xd electronics, this time Im testing Corolla parts. The Corolla wire harness and ECM will Terminate to the battery area, whereas the xd wire harness and ECM are run like the 1nz. I ran my Corolla harness over to the original ECM location and secured with zip ties until I know everything works. UPDATE: THE 2010+ COROLLA ECM IS NOT COMPATIBLE UNLESS YOU PLAN ON PROGRAMING NEW KEYS. I had to order a Scion Xd ECM because my car doesn't have immobilizer. For automatic transmissions the part # is 89661-52F71.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-20-2016 at 08:02 PM. |
#23 |
Data doesn't lie
This is a 2zr exhaust gasket against the 1nz collector, you can see there is a huge difference in size and this collector will need modifications to work. The bolt spacing on the 2zr exhaust manifold is also larger, its best to find a xd midpipe or collector and have the rest done at a exhaust shop.
#24 |
Data doesn't lie
Here is a xd airbox with the required 2zr MAF sensor. I got these items from Ebay, if you are not concerned about emissions then you can buy a aftermarket intake for an xd.
#25 |
Data doesn't lie
When you are ready to install the powertrain, remove this mount and bracket. The larger engine will not give you enough room to properly line up these mounts while mounted to the trans. Slide everything into place then install this mount last.
#26 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
I love these posts. reliving those moments at the storage shed swap. :)
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#27 |
Data doesn't lie
Once the powertrain is in and all of the mounts, suspension, and axles are secure....you can start installing your original hoses and lines. The heater hoses will need 2" trimmed off of the engine side, the fuel line will need to be flipped around and installed backwards(or buy one for an Xd), but the remaining brake booster, radiator hoses, and evap solenoid hose can be installed how they were originally.
#28 |
Data doesn't lie
Now you can assemble the rest of the car and it will look like this. If your car has a/c you will also need the compressor lines: Pn#88712-52341,88711-52311...then get your a/c system recharged. Next step....wiring.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-20-2016 at 05:40 PM. |
#29 |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
SOOOOO much WIN!
#30 |
Did you use XD axles, or Yaris axles?
#31 | |
I'm truly not trying to be a buzzkill, because this swap is AWESOME, and I really want to do this to my car. Just something to think about and investigate if your car is required to meet state emissions standards. |
#32 |
Data doesn't lie
Yaris transmission and axles on my car, Xd transmission and axles on another.....its up to you.
And about emissions, everyone should check their own states laws before starting any swap. I already have permission from California to do this swap, I called in advance. |
#33 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
As a side note do you know how much beefier the xD axles are if any?
Sent from m-o-b-i-l-e
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#34 | |
For reference, the Yaris uses 23 tooth 24/48 DP stubs, the xD (Celica/Matrix/Corolla) uses 20 tooth 20/40 DP stubs. I'm drawing a blank on how to calculate the actual diameter. The Quaife datasheets show the inner diameter of the xD differential inputs as 28mm, the Yaris as 27mm. **Edit** Some quick math with a gear/spline theory worksheet gives an outer diameter of 1.041" on the Yaris splines, 1.1" on the xD. No idea how big the shafts are past that, but a trip to the junk yard with some calipers would tell you. Last edited by CrankyOldMan; 01-19-2016 at 05:18 PM. |
#35 |
Data doesn't lie
Like Cranky said....visually they are also just a little bigger.
Like my Corolla exhaust....the ID is 46mm, Yaris is 40mm |
#36 |
Good to know. Could play a part in how people look at the swap for auto x, etc especially if they boosted it.
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
