Old 04-21-2016, 02:37 PM   #19
Originally Posted by tarkus View Post
lower profile tyres give better efficiency due to reduced rolling resistance.
How do you figure that? Rolling resistance is rubber compound, tread pattern, and contact patch.
Old 04-21-2016, 08:13 PM   #20
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I believe you can find articles about it online. As a ťyre rolls, the part in contact with the road flattens and the sidewall near that point deforms. As the wheel turns, the point of deformation moves around the sidewall causing significant rolling resistance. The taller the sidewall, the bigger the size of the deformation and hence the increased rolling resistance.
Sent from my LG-D801 using Tapatalk
Old 04-21-2016, 08:23 PM   #21
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I can see this to work with low pro and narrow tire, keeping the tire contact patch same size with little deformity as possible.
Sent from my ONE A2005 using Tapatalk
Old 04-21-2016, 09:19 PM   #22
enviri
enviri's Avatar
Drives: 2010 Yaris
I prefer a 16" over 15 for looks, generally better road feel, all in all better handling.
I use 15s for winter. 15s make the car feel quicker definately..I personally prefer 16s for better road feel.
Old 04-21-2016, 09:28 PM   #23
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Each to there own I guess, I find on a car with minimal power I stay with 15s for best over all performance but do agree larger wheels look sexy 😜
Old 04-21-2016, 11:21 PM   #24
kimona
kimona's Avatar
Drives: 2014 White VITZ
I ran 205/50/16's on my 2007 and now on my 2014. I can report go cart handling, no noticeable decrease in power compared to the 15's, and a very comfortable ride. But, gas mileage suffers a bit with 205mm rubber.
Old 04-22-2016, 07:50 AM   #25
tarkus
tarkus's Avatar
It's the main scientific reason that sports cars use low profile tyres. The cool look is an added bonus.
Old 04-27-2016, 04:57 PM   #26
texascolt45
Drives: 2015 yaris
got my 15" wheels.gonna scout out some tires tomorrow.205/55-15 I assume will fill the wheelwells a little better.not lowered.15X6.5 Konigs.40 offset.these wheels only weigh 11.5 pounds too.
texascolt45 is offline   Reply With Quote
Old 04-27-2016, 05:04 PM   #27
Perfect size combo
Old 04-27-2016, 05:06 PM   #28
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Why would you go with such a large tire I mean it will effect everything about your car, at least do 205 50 or 195 55 plus wider is not always better anyhow enjoy ur new wheels.
Old 04-27-2016, 06:21 PM   #29
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Congrats, looking fwd to seeing pics.
What color did you end up going with?
Old 04-28-2016, 12:53 AM   #30
tarkus
tarkus's Avatar
That's the same as I've got. Lightweight Konig rims with 205/55-15s. Comes out just very slightly bigger than the stock 185/60-15s.
Old 04-28-2016, 01:43 AM   #31
kimona
kimona's Avatar
205/55/15's actually work very well on the Yaris.
They are 4mm (2/10") taller than stock 185/60/15's on earlier models and 2mm (1/10") shorter than stock 175/65/15's on later models.
Pay attention to the tread pattern when choosing a tyre; to eliminate highway wander, avoid aggressive tread patterns and look for a wide, continuous centre band.
Old 04-28-2016, 11:46 AM   #32
texascolt45
Drives: 2015 yaris
my car for some reason has 175/65-15's for stock.maybe French built oddity.and yes I bought some cheap tires for my wifes mustang that had me chasing a front end problem for months.i'm probably gonna get something top of the line for this one.
Old 04-28-2016, 11:56 AM   #33
He said 175/65/15 is stock on later model years so you don't have an oddity.
I too would have opted for 195 series tires. I've had 195s, as well as wider and skinnier than that. 195 was my favourite size.
Old 04-28-2016, 12:02 PM   #34
kimona
kimona's Avatar
Unfortunately, there aren't too many choices in 205/55/15. Here are some options:
http://www.discounttiredirect.com/di...e&rd=15&cs=205
http://www.tirerack.com/tires/TireSe...r=17&zip-code=
Old 04-28-2016, 12:11 PM   #35
texascolt45
Drives: 2015 yaris
yea I saw that was and odd size kinda.the guy I deal with sells a lot of kuhmo's,thats what I had on my Tacoma twice I think.
Old 04-28-2016, 12:22 PM   #36
tarkus
tarkus's Avatar
I had 195/55-15s on my Echo RS, which had 14" stock rims. With the Yaris RS I've moved up to 205s (Goodyear Eagles) to keep reasonably close to its larger stock wheel diameter.
