Old 05-17-2016, 05:20 PM   #1
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I would recommend you stay with synthetic for future oil changes. If will help reduce further wear on this already heavily used engine.
Sent from my LG-D801 using Tapatalk
Old 05-17-2016, 05:39 PM   #2
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
TARKUS you think that would help? It does have a lot of miles on it lol everyone says that is k to go from conventional to synthetic as my understanding synthetic does help lubricate the engine better my only concern is that it didn't burn oil before until I decided to switch to synthetic last oil change
Ramon1691 is offline   Reply With Quote
Old 05-17-2016, 07:03 PM   #3
IMO stick with conventional or you're just burning money. In a high mileage vehicle like yours that doesn't see freezing temps there is no benefit. Dyno oil lubricates just as well as conventional in your climate.
I do run syn oil in my Echo that has 380k km on it but that is only in the few crazy cold months during the winter since it doesn't start as smoothly as it once used to. Once the temp rise I go back to conventional. FWIW I do notice slightly more oil loss with the syn oil, and the weight is always 5w30.
It burns about 1L every 1000-1500 km so I don't bother doing oil changes anymore, just the filter.
You may find adding an additive like syn lube or similar helps with the oil burning. It makes a big difference in my Echo, I suppose you could also just run a heavier weight oil as well.
I just find it hard to believe that this amount of oil burning just happened all of a sudden. This point to you needing to check the PCV, that said it could just be a beaten on enigne with failing rings.
Old 05-17-2016, 07:55 PM   #4
Ramon1691
Ramon1691's Avatar
In only went down a few lines like 3 or so a little down from the full mark I have after 1800 miles with the synthetic also I don't know whether the previous owner kept up with the oil changes that well when I bought it I did a whole tune up on it I'm just going to stick to conventional as you mentioned and just going to keep an eye on the oil every month or so I had my mechanic check the pcv valve and it was good I seen this cars last many miles I also got my serpentine belt done that bastard was full of cracks :/
Old 05-17-2016, 10:53 PM   #5
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
This stuff slowed my Land cruiser from burning oil.
http://www.walmart.com/ip/17018131?w...787248&veh=sem
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 05-18-2016, 01:30 AM   #6
tarkus
tarkus's Avatar
Synthetic still reduces friction wear, regardless of the weather. However, I take your point that if the car is just burning up the oil, you might as well use the cheaper stuff. Like you. I also think it's odd that the car just suddenly started burning oil, and I think that should be looked into.
That's exactly what I would recommend, once the underlying issue has been figured out.
Old 05-18-2016, 11:28 AM   #7
Ramon1691
Ramon1691's Avatar
Thank you TARKUS I will use that high Milage oil on my next oil change for now I'll just keep an eye on my oil level since I put conventional back in tho when I changed from the synthetic I noticed that it was really dirty with only 1800 miles on the oil is that normal? Maybe it was all the crap build up on the engine I'm not mechanically inclined but I don't see any leaks underneath or around the motor either
Old 05-19-2016, 11:42 AM   #8
I'm not familiar with the European Toyota engines but as far as I know the 1nz is not an oil burner until the rings eventually wear out.
Old 05-27-2016, 12:35 PM   #9
tarkus
tarkus's Avatar
I was told the 2.4 litre Camry would use some oil. Never happened on my wife's one. Maybe only using synthetic oil helps in some way.
Originally Posted by jack black View Post
Reports of prius oil burning, especially 2010.
No way! That's hilarious. The first green car that burns oil!
Old 05-27-2016, 02:09 PM   #10
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
yes, synthetic oil should prevent or slow ring deposits.
not really, it burns much less gasoline compared to other oil burning toyota cars (i personally had an oil burning corolla, LOL).
now, 3rd gen prius is speced for 0W20 synthetic oil. i suspect some places cheated and used dino instead. mine doesn't burn oil.
jack black is offline   Reply With Quote
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Did they increase the oil capacity for 09 Yaris? 2007yariz DIY / Maintenance / Service 8 05-18-2011 09:28 PM
