Old 07-28-2016, 10:01 AM   #19
rabbito
rabbito's Avatar
Originally Posted by invader166 View Post
No offence to the OP, but what are you comparing your car to, in order to reach the conclusion that it's "slow af"? It's important to keep things real, and compare apples to apples. If you try to compare your Yaris to a BMW or Audi, then you'll definitly be dissapointed.
no im not comparing them to bmw or audi..1nz engine is hard to gain hp with n/a set up(stage 1)..its just an opinion after completing the set up..i was actually comparing them to honda B series engines..😧😧😧😧
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 07-28-2016, 11:19 AM   #20
TRD SPEC
TRD SPEC's Avatar
Drives: Ncp42
Comparing to 1zz its pretty good
Sent from my 3006 using Tapatalk
TRD SPEC is offline   Reply With Quote
Old 07-28-2016, 11:41 AM   #21
alias06
Drives: 2008 Red Toyota Yaris
sigh.....put some photos of your car man, stop being a keyboard racer..😂😂😂😂
I'm not sure what photos of my car would prove? You want to see if I've modded my Yaris like yours? The answer is no, does that necessarily mean that I am ignorant and what I've said is false? No.
alias06 is offline   Reply With Quote
Old 07-28-2016, 11:43 AM   #22
alias06
no im not comparing them to bmw or audi..1nz engine is hard to gain hp with n/a set up(stage 1)..its just an opinion after completing the set up..i was actually comparing them to honda B series engines..��������
Compared to B series? Why? Lol....It's better than a 1zz? I guess, all those mods and still can't compare to a bone stock 1zz but I guess you can say its better
Old 07-28-2016, 11:47 AM   #23
rabbito
rabbito's Avatar
get outta here lol😂😂😂😂
Old 07-28-2016, 12:30 PM   #24
alias06
I've just said that your car is slow, and with the mods that you currently have it is still slow. You yourself have said that it is slow, you think that the mods you've done will make your car much faster, I've simply stated that it won't.
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 08:01 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
