#1 |
![]() ![]() ![]() Drives: Twin-charged rotary V8 w/nos Join Date: Nov 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
What's up!
Thanks, bro! She's going in for an alignment tomorrow. I added a little more negative camber to my front left, and I need them to correct the toe spec from that added change. Also, the roads I drive on suck, so I'm sure something has gone out of spec since the last time I took her in for an alignment. So OEM shoes are back on in the meantime (rather risk nicks to those than the WedsSports). |
#3 | |
#4 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
I don't like how they are flat and the piston is always dragging on the bottom of the cylinder. seems like it would cause more wear. I don't like how you have to perform 2 head jobs every 70,000 miles or so. I don't like the sound they make, and how they basically run like two 2cylinder engines in opposition. manly, I don't like the people whom drive Subaru. (in my area) they are so self riotous and pompous I could puke
#5 | |
The 86 doesn't sound like a "Subaru" since Subaru utilized an EL header. I actually want to replace it with an UEL header to get that boxer burble. ![]() In my area, it seems like EVO owners are what you described. lol. |
#6 |
Decided to add this carbon fiber strut bar so that the engine bay isn't too boring.
![]() ![]() And yes, I know this does nothing for my car. lol. Last edited by Kaotic Lazagna; 12-03-2017 at 10:33 PM. |
#7 | |
Are you on Wheelwell? |
#8 |
#9 |
How my work day started...this was the second time I got stuck...and then right after I got pulled out, I got stuck again. bah
![]() Gravel is surrounding the exhaust pipe, touching the LSD, and pretty much everything else: ![]() ![]() The rear wheel was pretty much in the air since it was fully extended. |
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
#12 |
#13 |
In addition to installing the HU in Dory, I installed these Morimoto switchback LEDs in Snow White. Comparison pics. Passenger side is always the LEDs, and driver side is always OEM.
Turn signal ![]() Parking light mode
#14 |
Here's a couple night shots of those switchbacks:
![]() ![]() Great lumen output in parking light mode (anymore, and I think I'd get pulled over). However, turn signals are just not enough. I can't see them flashing on the ground from the cabin. Last edited by Kaotic Lazagna; 12-03-2017 at 10:36 PM. |
#15 |
Swapped out the OEM rear turn signals with VLEDs HVA bulbs (I'll swap Dory's on my days off since I have to swap the flasher relay on her still)
![]() ![]() I'm sure you guys can tell which is OEM and which is the VLEDs. lol Last edited by Kaotic Lazagna; 12-03-2017 at 10:37 PM. |
#16 |
Decided to drive her to work today. Filled her up with some 100 octane on the way home.
#17 |
Very nice
#18 |
white + slammed +100 = yea!
| 1.5" Lower front & back: Snow issues? | jmanous | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 01-28-2016 12:14 PM |
| white plasti-dip and white yaris | bcuzau | Third Gen Yaris General Discussion | 4 | 07-20-2014 11:19 AM |
| My wheel dreams crushed or, how heavy is too heavy? | Yaristeve | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 39 | 12-18-2012 07:06 AM |
| toyota belta jdm customize 2007 POLAR WHITE pic | toyota-belta | Photo-Video-Media Gallery | 24 | 09-30-2007 03:36 PM |
