#19 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
You are correct in saying that the theoretical amount of air that can be drawn in the engine is 100%. But, that's only THEORETICAL! In reality it's probably more along the lines of 80%-85%, but that's besides the point. On a naturally aspirated engine, with a well designed induction system, you can definitly break that 100% mark without forced induction, using a process called pressure wave tuning. Definitly look it up if you don't believe me. I'm not making this up.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#20 |
Given that one of the first things people do to improve performance on just about any car is intake/exhaust system to let the car "breathe", gaining power from it makes sense to me.
#21 | |
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
Don't get me wrong, a well designed intake/exhaust setup will increase power. But blindly adding parts because everyone else does is stupid. |
#22 | |
You must also skipped over the part where I said "tuning for a certain RPM" even with pressure wave tuning it is only tuned for a specific RPM that is why there are different length headers which move the powerband up or down depending on the design. The engine itself can't achieve 100% VE at all RPMs, it can be considered a narrow powerband when compared to a FI engine where a compressor is used to force air in and increase VE of the cylinders. |
#23 |
![]() Drives: Yaris '07 Join Date: Jan 2016
How's the power gain vs gas efficiency ?
Envoyé de mon iPhone en utilisant Tapatalk |
#24 |
#25 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
if you live in a hot ass country like me(40c with 100% humidity)..sri or cai will be same as drop in with slight gain...i really recommand sri or cai in cool country... Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#26 |
#27 | |
| FS: OEM Toyota Vios Turbo Kit | CTScott | Items for Sale by private party | 24 | 07-31-2011 09:12 AM |
| FS: Partial HKS turbo kit for Yaris | 33OH | Items for Sale by private party | 18 | 07-23-2011 03:37 PM |
| Greddy xB kit vs Greddy Fit kit | ellenbetty | Forced Induction Forum | 52 | 09-29-2009 08:42 PM |
