Old 12-30-2016, 10:05 AM   #1
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I certainly hope these bolts are at least made from a better material than OEM. I guess it might be ok to run a bolt like this for regular road driving, but on a track under heavy loading......lets just say I'd be a little more concerned about that crash bolt sheering off due to less material.
Then again, my concern could be totally unfounded. At any rate, definitly go spend some extra cash to get the good stuff, and avoid cheap knock-offs.
Old 12-29-2016, 10:11 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
The Whiteline bolts sure look like reboxed SPC bolts. Funny that they have a different range spec. Cam bolts are intended to be put in the top holes. As mentioned, just put the one pair in and go from there. Most people won't need more than that.
Old 12-30-2016, 06:38 AM   #3
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Should be the bottom
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 12-30-2016, 03:40 PM   #4
CoryM
They always specify the top. It gives better angles, and may have less force on it.
http://www.spcalignment.com/instruct...40-INS_WEB.pdf
Invader166: Cam bolts hold up fine on track and at autoX (where loading is typically higher). Personally I'm not comfortable that two bolts are safe (and they do specify to only use one set), but I believe Jason runs two in his racecars with no issues.
Cheers.
Old 01-01-2017, 01:42 PM   #5
invader166
Pumpman
Cheers.
I see...thank you for providing more info Cory.
coilover questions why? Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-11-2012 01:58 PM
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
Brand New Suspension Questions... silaypalmer13 DIY / Maintenance / Service 5 03-13-2009 01:26 PM
A few questions about suspension, tires, and brakes. supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-02-2009 04:55 PM
