Old 06-17-2007, 01:58 PM   #19
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
Originally Posted by churp View Post
How does a sway bar get stiffer??????? (not that stiffer is needed) only way is larger diameter, or change the distance/length between attachment points....research.
Or, technically, the material will also make a big difference. Think of mild steel vs. 4130 cromoly in the same diameter. Also shape (box v. oval v. round for example).
Because there is no ltd. slip, and not much power, more sway would only increase the likeliness of the inside wheel lifting under hard cornering...
I can tell you the coil-overs made such an improvement, it might be all you'll ever need. Also, the rear end is huge for a car this size, it looks pretty damn beefy.
Check out the TEIN project car, it has some interesting mods to it.
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
Old 06-18-2007, 10:05 PM   #20
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
I think they mean more tension is added which means mroe pressure on the brace/bracket/bar/whatever.....
right as the shock body where the bar's end link is fixed moves upward with lowered springs, thus adding extra tension on the bar. And it's really noticeable
hystria is offline   Reply With Quote
