Old 01-25-2017, 09:07 AM   #19
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Well if emissions is not a problem in NZ maybe you should backdate your ecu and throtle to gen 1 :)
Or try those kits that remove the lazynes from the systems with e-throtle.
Good luck
ncp13 is offline   Reply With Quote
Old 02-01-2017, 03:46 AM   #20
SlowVitzRS
Drives: 2005 Vitz RS Manual
Success!
The 1ZZFE throttle body conversion fixed the throttle response and power drop after 5k rpm.
Here is the write up:
http://sergei.nz/toyota-vitz-rs-and-...ttle-response/
SlowVitzRS is offline   Reply With Quote
Old 02-01-2017, 07:23 PM   #21
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Originally Posted by SlowVitzRS View Post
Success!
Great write-up! Really informative.
If you're not looking to get a new intake manifold, you could also buy a throttle body spacer, and shave it a bit to match the diameter of the 1ZZ throttle body. Sadly that would also mean having to get longer hoses...
http://www.ebay.com/itm/X714-A-THROT...-/272517091875
Old 02-01-2017, 07:34 PM   #22
SlowVitzRS
I am looking at getting a spacer cut out of 6 or 8mm alloy plate and have slope ground in the opening to match two diameters in a gradual fashion.
Old 02-01-2017, 08:55 PM   #23
SirDigby
Drives: 2007 yaris 3 door
I made my own spacer. it was a pain, but it turned out awesome and it was fun! (no longer hoses required)
http://www.yarisworld.com/forums/showthread.php?t=55767
http://www.yarisworld.com/forums/showthread.php?t=56265
and you should port your manifold. or you can buy mine in April when I sell it.
http://www.yarisworld.com/forums/pic...pictureid=6102
http://www.yarisworld.com/forums/alb...pictureid=6101
http://www.yarisworld.com/forums/pic...pictureid=6100
http://www.yarisworld.com/forums/pic...pictureid=6103
http://www.yarisworld.com/forums/pic...pictureid=6104
http://www.yarisworld.com/forums/pic...pictureid=6105
http://www.yarisworld.com/forums/pic...pictureid=6107
Old 02-02-2017, 04:08 AM   #24
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
I am thinking that maybe your throtle body was defective and not opening as much?
I have tried 1ZZ cable throtle body on my 1nz and I did not see much.I lost low end throtle response and it was happy at high rpm.
Its great that you got the power back.
Old 02-03-2017, 08:08 PM   #25
SlowVitzRS
Nope, throttle was not defective (otherwise it would thrown a code).
What actually is wrong in my opinion is not the throttle size, but throttle map. the 1ZZFE throttle due to size simple overrides map as 70% opening might as well be 100% (compared to original). Toyota gimped too much the throttle map.
I can bet I would got the same result with a throttle controller.
With manual throttle if you give it 100% it is guaranteed to be 100%. With drive-by-wire not so much. Drive by wire were introduced because this way they can reduce emissions during transients (ie when you plant your foot down suddenly), and smooth out torque curve to make it more flat (at expense of peak power).
Old 02-11-2017, 08:09 PM   #26
SlowVitzRS
A follow up:
I discovered that on cold the idle would shoot up to >3k and sometimes would oscillate.
There also was an occasional harsh overrun transition.
Since then I have made a plate up and fitted between the 1ZZFE throttle body and 1NZFE manifold, this serves two purposes:
1) Ensure the O-ring seals properly
2) Provide a smooth transition between two diameters.
To remedy the oscillation I turned adjuster screw 3 times counter-clockwise.
http://sergei.nz/toyota-vitz-rs-thro...ting-out-bugs/
Old 02-12-2017, 03:00 PM   #27
SirDigby
yeah that's pretty high. I turned mine until it was idling at like 1800. I turn it wile the engine was running. at warm idle it was at like 450, and it threw a check engine light. I would bump the screw about 1/4-1/3 of a turn at a time until the check engine light stayed off. took like 2-3 times to get it right. at very cold it will start at 2400 for about 3 seconds, then drop to 2000-2100. after about 20-30sec it will drop to 1600-1800. at full warm idle is 550.
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 12:25 PM
Toyota yaris hatchback headlight fits on Vitz 2005? urguardian Cosmetic Modifications (Exterior/Interior) 2 09-11-2014 04:46 PM
Vitz 2005 Battery mudi General Yaris / Vitz Discussion 0 09-07-2011 02:28 AM
Toyota Vitz 2005 1.3L Auto Air Filter technoguy DIY / Maintenance / Service 4 01-11-2011 02:45 AM
Vitz 2005 in UK. lappie General Yaris / Vitz Discussion 0 03-12-2006 10:02 PM
