Old 06-19-2017, 12:01 AM   #19
alias06
Drives: 2008 Red Toyota Yaris
Originally Posted by heeroyuy01195 View Post
Coilovers can help with straight line drag racing. Depending on how they're setup, you can improve your traction on launch and reduce "bob" while shifting gears which keeps the wheels planted so more power to the pavement. Minimal improvement on an underpowered car like the Yaris but milliseconds count.
Yes a well set-up suspension can help anywhere, but switching from a good spring/strut combo to an off-the-shelf setup isn't going to make a huge difference.
alias06 is offline   Reply With Quote
Old 06-27-2017, 07:51 PM   #20
ccyaris
Drives: 2012 Yaris L 3 Door 5 S
Installed KYB AJX, good range settings 1-5, keep it on 1 for daily driving, and won’t shake out your dentures.
ccyaris is offline   Reply With Quote
Old 07-04-2017, 07:09 AM   #21
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I wanted coil overs in a way, but because I tow and carry weight sometimes, went with the stiffer (and taller) springs, the Mexican rough road from Yota. I also put the TRD struts n shocks, n changed the sway bar end links while apart.
Handles great and is everything I wanted and one thing I didn't want, high speed lift. Over 85 mph, the front took me a few months to get used to, as the raising of the center of gravity made it handle differently, and lift at higher speeds. I think I can counter this with a custom lower sitting front lip, but try and not hang out at the high speeds unless I have drift space. After driving a couple months, I seemed to have gotten used to the new way it handles, and if I didn't tow anything, would have just went with TRD lowering springs.
Of course I wanted the dual adjustable coil overs, but couldn't justify the expense as I don't race it on a circuit, just A to B and the fun.
Ideally, I would have just changed rear shocks and went with stiffer spring rates same height, but no one makes that unless custom, also higher dollar than wanted.
In the end, because of towing or weight carrying, my mix is good for me and I am happy overall.
need help on megan coilovers chexmix Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 01-26-2016 04:13 AM
FT: Tein basic Coilovers SOCAL!!! Mister Z Items for Sale by private party 0 03-27-2011 05:24 PM
Megan Coilovers $550 including install!!! Walter Items for Sale by private party 14 09-29-2010 12:01 PM
FS: Tanabe Sustec Coilovers thebarber Items for Sale by private party 6 07-16-2010 10:53 AM
FS: Megan Coilovers and Megan Axleback Exhaust thebarber Items for Sale by private party 19 04-08-2010 04:06 PM
