Old 06-08-2007, 08:56 AM   #19
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
If anyone ever wants to check the integrity of a small piece like the pulley stop by a machine shop and have them magniflux your part. It is rather cheap and does not take much time at all. The only problem you might encounter if finding a shop that will take on small jobs.
blacksan is offline   Reply With Quote
Old 06-08-2007, 03:34 PM   #20
carlosh
carlosh's Avatar
Drives: Yaris Sedan 2005 Motor 1NZFE
Send a message via MSN to carlosh Send a message via Yahoo to carlosh
Originally Posted by joey1320 View Post
hablas espanol???
i haven't noticed any vibrations at all, with or without the a/c on. and the belst are cheap and easy to replace, so if theres some premature wear i really don't care
Hola si hablo español, tu tienes instalada una polea unorthodox?
Yaris/echo 1NZFE NCP12
-> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar
-> TRD Performance air filter, Stage 1 Gripforce F1 clutch
carlosh is offline   Reply With Quote
Old 06-08-2007, 03:52 PM   #21
YarisGuy
Drives: 2006 Yaris
Originally Posted by ism3t View Post
i was honestly ROFLing after reading this.
quite rude , but GOD DAMN it was well spoken .
Just being honest and speaking factually instead of throwing out an opinion
Thank you for noticing
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 06-08-2007, 04:58 PM   #22
carlosh
carlosh's Avatar
Originally Posted by carlosh View Post
Hi, i use since 1 year a cranck pulley Unorthodox underdrive and have a bit of vibrations when the AC and WP are working, but nothing to worry. the only problem that I have is about the wear of the belt (premature wear). But this I am happy yet with my pulley it gives a performance about 10HP
these vibrations occur when to the parked car (while I am in a semaphore for example, and the radiator fan is ON + AC ON ). I think this must to the car computer (when I install the pulley and reset the compu..) adjusted the revolutions of the motor by the low weight of the pulley (the underdrive pulley do this accesories run slow).
Old 06-09-2007, 11:05 AM   #23
joey1320
joey1320's Avatar
Drives: Yaris LB
el mio esta bien, no me a dado ningun problema. buena suerte!
ZPI, great customer service. joey1320 Performance Modifications 3 05-17-2007 03:06 PM
ZPI Pulley worth it? jamal1984 Performance Modifications 11 04-11-2007 03:15 PM
ZPI pulley installed! PetersRedYaris DIY / Maintenance / Service 5 04-10-2007 07:31 PM
ZPI Crank Pulley Installed! Papamoon Performance Modifications 3 03-02-2007 11:35 AM
