#1 | |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
That's exactly how much I spend on pizza every week. Plus the tip. Best price I had so far for a 5L of Napa premium synthetic oil is $23.85 CAD with taxes on sale. |
![]() ![]() Drives: 07 yaris Join Date: Dec 2016
I bought my yaris with 200,000km and now at 270k in 2 years. Only use standard 5w30 and it's been excellent. Changing every 7-8000km. Mix of town and highway driving. Car runs like new still.
#3 |
![]() ![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
That motor just finished breaking in
@ 168,000 miles. That car has a ways to go! You are changing it by service standards so it will work. Good luck with it. |
#4 |
I use Dexos certified Synthetic oil 5-30 from Wallmart and Hi capacity/ large Wix filters.
The maintenance light comes on and the oil is changed. I received the car with 17,ooo miles in 2020, it has 72,ooo on the clock. I change the Tranny at thirty thousand and sixty (simple grain and fill appx. three quarts). I changed spark plugs NKG replacement at 50,ooo. I will Bleed brakes in the next few weeks to keep that system clean. My car runs like it is new! For a Toyota it almost is! It just purrzzzzz! The best of luck on your decision. "Oil and filters are cheap!". Engines are expensive... simple math. I have higher end drilled and slotted rotors, and Brembo Pads for when I Bleed the brakes. |
#5 |
![]() ![]() Drives: 2009 yaris Join Date: Feb 2016
My '09 1.5 5speed manual has been getting 10-13k mile oil changes with the super tech brand from Walfart, and their filters too. I have upwards of 270k miles on it now. I get 42mpg winter gas, 48mpg summer blend, easily. I changed my oil yesterday, I lost almost 3/4 of a quart in 10,400 miles. I'm mainly highway and suburb driving though.
#6 |
![]() ![]() Drives: Hatch Join Date: May 2009
I bought my 2007 hatchback new. At 67,000 I switched over from dino oil to Mobile 1 and that's what I've been using ever since. I run it 8,000 miles, with a filter change at about 4,000. I've used Baldwin B33 filters from the beginning. Car is now at 154,000 and all seems to be fine.
I'm in the north. I get about 34-36mpg in the summer w/o ac. In the winter it drops to anywhere from 29-34 depending on how bitter the cold is. |
#7 |
![]() ![]() Drives: Yaris T1 Join Date: Aug 2020
Bought yaris gen 2 in 2007. Did oil changes with Toyota Genuine oil every 15000km with 1 extra oil change half way through each interval. (so every 7500km)
When Covid started, I accidentally bought too much oil (did not see expiry dates on bottle) So I had to reduce OCI to 3 months for a period of three years 2 months ago, I cracked my oil sump. Had it changed and I saw varnish at the bottom of the oil sump, at least a quarter of the sump had varnish. So screw it, I change oil every 6-8 weeks now. I leave the filter for 6 months. |
#8 |
![]() ![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Oil doesn't expire.
#9 |
| my first DIY oil change since 1988 | justanotherdrunk | DIY / Maintenance / Service | 15 | 03-01-2017 10:58 AM |
| Should I Change My Oil After 1300 Miles? | bronsin | DIY / Maintenance / Service | 3 | 10-28-2016 01:25 AM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
