Old 05-22-2007, 10:30 PM   #19
joey1320
joey1320's Avatar
Drives: Yaris LB
if you feel bad about the smog you greate then plant a tree and don't give this company shit. is a scam. the earth will do without us!
Old 05-22-2007, 10:33 PM   #20
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Common sense doesn't prevail with the green people, otherwise how do you explain.......a Honda 600 coupe being disqualified after winning the economy portion of a rally due to failing emmisions, while the same year cadilac with 472 ci can't get above 13 mpg but passes all emisson tests......a government study a few years ago found a tree that dies in the woods puts out more emissions in the 30 years it takes to rot than if you burned it to heat your house, yet all kinds of local governments make ordinances against woodburners......the current green classifications for cars, the top 2 classes have cleaner output than the air is currently in LA, why don't the LA officials put these engines thoughout the city just to clean the air.....etc. etc.
Needless to say I don't care for Green, I like efficiency. Sort of a twist on what Toyota said about overtaking GM in sales....."If we build for efficiency the rest will come."
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 05-22-2007, 10:44 PM   #21
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I want Nuclear everything.
SPONSORED BY
