Old 11-23-2017, 06:10 PM   #19
Ab9000
Drives: 2008 Yaris hatchback
im having the same issue and its getting scary driving on the freeway. I went to a Firestone and they checked shocks/struts which were okay. They put on new tires and did an alignment. The tires are Champion Fuel Fighter BL 185/60r15. Are these okay tires?
With that wandering/floating feeling is there any chance the car can just flip over? It certainly feels like it when the freeway veers right.
Ab9000 is offline   Reply With Quote
Old 12-05-2017, 01:10 AM   #20
bairjo
If your car does not have one already, get a rear sway bar installed first, then consider new tires if still needed..... they are easy to install. just do a diy rear sway bar search on here for more info.
Old 12-05-2017, 08:50 PM   #21
I don't think I've ever mentioned before. Be careful when just adding a rear sway bar to a stock car. The car will oversteer more in corners.
Sent from my SM-G930W8 using Tapatalk
Old 12-05-2017, 11:37 PM   #22
bairjo
[QUOTE=IllusionX;806759]I don't think I've ever mentioned before. Be careful when just adding a rear sway bar to a stock car. The car will oversteer more in corners.
Be careful at first but don't worry about it....i added one to my Yaris and on the flip side i would probably be concerned about how it handles if someone were to remove the sway bar without telling me..
Old 03-01-2018, 08:44 PM   #23
David C
Drives: White '07 3dr LB
Just add a few bags of sand in the spare wheel well. With an extra 80-100lbs or so on the rear axle you'll be just fine driving up to 80mph. With 150lbs on the hitch and 100lbs in the rear I got up to 100mph before the car felt a little float with a (driver) single occupancy.
David C is offline   Reply With Quote
steering wheel slight vibration high speed??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 10-01-2012 06:36 PM
HIGH SPEED YARIS CRASH.... ROCKLAND TOYOTA Photo-Video-Media Gallery 23 03-10-2012 08:59 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Have I mentioned how much I hate Speed sensors? staticorex General Yaris / Vitz Discussion 13 05-28-2009 04:04 PM
Six speed Snyprwlf47 Performance Modifications 16 11-24-2008 09:04 PM
