Old 01-21-2018, 09:01 PM   #19
enviri
enviri's Avatar
Drives: 2010 Yaris
https://youtu.be/G1oSPgxv1zo should take care of everything,
https://youtu.be/WwKyBosf05s is wiring to the car.
Old 01-21-2018, 09:55 PM   #20
enviri
enviri's Avatar
Drives: 2010 Yaris
Old 01-22-2018, 12:16 AM   #21
govtec
Drives: 2007 Toyota Yaris Hatchback
Great, thanks dude! I see you got the auto-leveler...I'm not planning on using that.
govtec is offline   Reply With Quote
Old 02-26-2018, 04:06 PM   #22
enviri
enviri's Avatar
Drives: 2010 Yaris
i didnt use it either. i'd have to replace one of the switches for one with auto leveling, then route wiring to that leveler thing...yeah dont need it. It's rusting away at a good pace
Old 02-28-2018, 12:01 AM   #23
David C
Drives: White '07 3dr LB
So what's the approximate cost to do the conversion ?
David C is offline   Reply With Quote
Old 02-28-2018, 11:18 AM   #24
enviri
enviri's Avatar
Drives: 2010 Yaris
depends how lucky you are on getting a complete headlight unit, and how patient you are on shipping. the headlights are 30-100 USD on jp auctions. the necessary wiring is a good 50 or so. Assuming that the headlights came with ballast and the bulbs are in there, that's your bare minimum cost+shipping to your home. (ems shipping for these are about 150 to east coast usa)
Old 02-28-2018, 12:00 PM   #25
David C
Ah, yeah it's a little bit of knowing what you're doing and buying project. Not sure I am committed enough to go that route.
What I really feel that is missing on the Yaris light output is the medium to close range, it's like the beam pattern doesn't light down the road enough and it's not relaxing at times especially in dark rain or poorly lighted roads structures like overpass and access ramps. I really like how much the LED fog light setup of IllusionX fills up the lower parts of the road, I'm thinking I may very well just slap an LED bar in the front grill and carefully select and aim it so it doesn't blind anyone.
Old 02-28-2018, 12:14 PM   #26
enviri
enviri's Avatar
Drives: 2010 Yaris
fog lights help immensely in that range. I have the morimoto XB LED fog lights, never looked back.
Old 03-04-2018, 02:27 PM   #27
David C
What do you think of these ? I'm not familiar with what's real and what's gimmick in terms of projectors and lights, but I'm thinking it could be nice if its a real HID projector setup ?
https://m.ebay.com/itm/YARIS-XP90-MK.../112525893808?
Old 03-25-2018, 02:38 PM   #28
fredovvti
Drives: Yaris 07 HB
Hi,
Anyone can help me, I buy this headlights but can make work. I see the pictures make the right connect, but went a put it in the car, they dont work. Please you can but a clear instructions to how connect the extra ground?
Thank you!
Sent from my SM-N950F using Tapatalk
fredovvti is offline   Reply With Quote
Old 03-25-2018, 04:03 PM   #29
fredovvti
Drives: Yaris 07 HB
Originally Posted by enviri View Post
Also you might start poppin fuaes on headlight use like i did. I went against ctscott's recommendation and went +5a... Although i think +2.5a is enough, maybe?
Where you change the fuses?
Old 03-25-2018, 06:49 PM   #30
enviri
enviri's Avatar
Drives: 2010 Yaris
fuse box in engine bay
#17-18
Old 03-25-2018, 06:51 PM   #31
enviri
enviri's Avatar
Drives: 2010 Yaris
the extra ground is needed for the parking light (little bulb), so an extra wire goes from the ground for that parking light to the chassis.
Old 03-25-2018, 07:00 PM   #32
fredovvti
Drives: Yaris 07 HB
#17-18
So, does 2 fuses arw #10. I have to go up to #30 both?.
Old 03-25-2018, 08:12 PM   #33
enviri
enviri's Avatar
Drives: 2010 Yaris
12.5 or 15. I went with 15. CTScott recommended against it for fire hazard, but its the only way for my headlights to stay working...and its been years since i changed it with no issue. no flicker, no premature blown anything.
Old 03-25-2018, 08:15 PM   #34
govtec
I wouldn't do that, there is a reason the fuse is at 10amp. You have to ground it properly. Did you try enviri's suggestion? I didn't get a chance to install my headlights yet because of the weather and school.
Old 03-25-2018, 08:19 PM   #35
govtec
What year is your car? I accidentally ordered a pair of post facelift JDM HID headlights that I will sell soon here in the states once the weather warms up and I install the pre facelift headlight in my car. The only thing that is missing is the ballast which you can get off of ebay easily. I can definitely sell it to you if you want to wait little bit.
Old 03-25-2018, 08:28 PM   #36
enviri
enviri's Avatar
Drives: 2010 Yaris
USDM lexus ballasts work well
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 10:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 06:30 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 06:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 02:56 PM
