Old 05-03-2018, 03:57 PM   #19
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Your patience will become legendary.
Haha. My wife points out that this potentially 'legendary patience' does not transfer to all aspects of my life.
One could also regard this as OCD, I suppose.
Old 05-03-2018, 06:37 PM   #20
06YarisRS
First rough bondo...
Old 05-03-2018, 08:13 PM   #21
Runethecursed
Drives: 2009 Yaris S
Moving right along arent you
Runethecursed is offline   Reply With Quote
Old 05-03-2018, 09:27 PM   #22
06YarisRS
Yes, however slowly. Here is the beginning of the end cap fabrication. It looks pretty darn rough now, but with bondo, spot putty, I think I can make it look pretty good - well, acceptable anyway.
Open end before cap install.
Rough shaping before sanding and getting the contours as close as possible...
End cap attached. I used some 'super strong' gel super glue to attach the end cap. Then filled in behind with expanding foam. Still have to wait for the foam to dry before removing the screw and also have to fill the two holes. I'll drill and screw the end cap into the bumper after it's fully set. Then, do the body work.
I'll use a toolable and paintable caulk or seam sealer to close up the top crack where the lip meets the bumper
First rough bondo. Needs some serious shaping. Ran out of 80 grit and sliced my finger open with the utility knife, so will stop for a day or so.
Driver's side now. Expandable foam does a great job adhering the lip to the car. Will fabricate the end cap soon.
Final sanding tomorrow. Apply caulk along top. Prime, sand, base coat and clear coat.
Old 05-08-2018, 07:52 PM   #23
06YarisRS
Ongoing...
More shaping needed. This has proved to be very difficult restoring the lines and curves after bending, warping and screwing the lip to the car. I am optimistic that I can get a tight, seemless connection at the top. I'll be using 35 year acrylic caulk which is easy to work into a thin, straight bead with cloth and water.
At some point soon I'm just going to call it quits and sand and paint. I'm gaining more and more respect for autobody technicians by the day.
No doubt after all this labour I'll scrub a curb and the entire thing will blow into pieces.
Old 05-08-2018, 11:04 PM   #24
Runethecursed
Keep up the hard work, its really comin together
Old 05-09-2018, 06:22 AM   #25
06YarisRS
Thanks man! I'm fighting the urge to paint. Of course, once I start spraying the base coat, every tiny imperfection will jump right out.
Old 05-09-2018, 06:31 PM   #26
06YarisRS
Caulking done and another layer of primer. One last round of spot putty, priming and block sanding and the base goes on.
Old 05-11-2018, 05:58 PM   #27
06YarisRS
First coat of paint. Will wet sand and repaint a couple more coats. I ordered two cans of SprayMax 2K Clear which I will apply in a few days. It should bring the ultra shiny glare down a bit and match the OEM paint better. The final effect will be acceptable. It looks good at a distance, not so great right up close.
Old 05-11-2018, 07:09 PM   #28
kimona
kimona's Avatar
Drives: 2014 White VITZ
Looks great in your photos!
Old 05-11-2018, 08:08 PM   #29
06YarisRS
Thanks. It's growing on me. Especially as the sun goes down.
Old 05-11-2018, 08:48 PM   #30
kimona
kimona's Avatar
Looks like you had a beautiful day in your neck of the woods.
Old 05-12-2018, 01:13 AM   #31
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Looks fantastic. I've always been envious of guys who could do bodywork.
Old 05-12-2018, 03:04 AM   #32
06YarisRS
It was, Kimona. It was indeed.
Old 05-12-2018, 03:10 AM   #33
06YarisRS
Thanks very much, NYC-SE. "could do bodwork" is a relative term.
Old 05-12-2018, 04:29 PM   #34
Runethecursed
Looks great, from experience, no one looks as closely as the guy who made it ;)
I really like how it all comes together!
Old 05-12-2018, 06:40 PM   #35
06YarisRS
Thanks a lot!
Once I got prepped to clear coat the lip, I decided to do the whole bumper as it had a lot of dings and chips, so I set to it with bondo, spot putty and a lot of sanding. It turned out reasonably well, but I have to do some blending as the paint just slightly lighter than the factory even though it's color matched.
The SprayMax 2K clear is really amazing stuff. Such a deep gloss. It will be considerably glossier after it's cured and I wet sand and polish. I popped in a pic at the end of my tailgate. I was never quite happy with how dull it was with the standard spray can clear coat. This is only with two coats of clear.
Paint without clearcoat:
2 coats clear:
Liftgate. I still have to do the bumper with clear. I cut a major corner here and applied adhesion promoter over the badges too. They may peel. Either way, I've been pricing gear to set up a paint booth/compressor, paint gun etc. I am really leaning toward a full repaint of this car.
Old 05-13-2018, 09:14 AM   #36
06YarisRS
Bumper/Fender Paint Blending...
I had a fairly sharp cut off line so I sanded it all out with 180/320/600 then blended the bumper into the fender. Also fixed some scratches and small dings on the fender while at it. I'm quite impressed with the blend I got with spray cans. Not a bad spray pattern from the Duplicolor Perfect Match (a slight misnomer ) I'm clear coating soon. Will post more pics.
It's hard to tell with all the sun glare but the blend is almost unnoticeable. We'll see what happens with the 2K clear goes on.
SprayMax 2K Clear. If you spray this stuff... most importantly USE A RESPIRATOR, long sleeve shirt and nitrile or latex gloves! It can do very nasty things to your constitution!
First coat of clear. A bit matte but subsequent coats should bring that deep gloss SprayMax is known for.
Done. I had to rush the car into the garage as the wind started picking up and a fog bank was approaching. You can see it over the trees just to the left of the van. Thankfully it pulled back out to sea a bit before ruining my paint job. Sunny and calm one second, foggy and windy the next around here. I decided to paint outside because I don't really have adequate lighting and in some ways it makes sense to paint it out in the light as that's where it will live. Will post pics after it's dried and then after wet sanding and buffing.
Will post pics after wetsand and polish. Should really bring out the gloss.
Now...off to celebrate Mothers' Day with the fam.
Feeler: Supercharger, JDM RS Front Bumper, Shorin Front Lip wildmongoose26 Items for Sale by private party 39 03-25-2015 06:13 PM
Ebay front lip will it fix my cracked bumper? ivanstepul Cosmetic Modifications (Exterior/Interior) 0 02-13-2014 05:28 PM
JDM Shorin Front Lip on RS Front bumper. Hots! wildmongoose26 Photo-Video-Media Gallery 18 06-14-2013 06:53 PM
i need help/opinions for my front lip donchae Cosmetic Modifications (Exterior/Interior) 2 12-10-2010 06:54 PM
Ordered mine today... now the wait begins boris13 New YARIS Purchase Forum 1 11-10-2006 07:40 PM
