Old 08-23-2018, 11:59 AM   #19
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Wheels Ready for Install
Wet sanding with 1500 and 2000
Polished wheels. These will bake in the sun today and go on the car tomorrow. I laid the clear on good and thick so they should be quite durable.
Old 08-23-2018, 03:58 PM   #20
kimona
kimona's Avatar
Drives: 2014 White VITZ
Excellent work. Have you got new rubber going on your wheels?
Old 08-23-2018, 06:59 PM   #21
06YarisRS
Thanks! I have a set of 195/60R15 with about 9/32 tread left. These were the tires I bought used and had installed on my other Yaris. I like the slightly wider tire and thought it would look best on the RS. Will post pics tomorrow.
Old 08-23-2018, 07:20 PM   #22
kimona
kimona's Avatar
195/60/15's are a good fitment. Waiting for the photos.
Old 08-23-2018, 07:59 PM   #23
06YarisRS
I agree. I'm pretty sure that there will be no rubbing issues with the Penguin 13mm spacers and the 195's. I was running the 185/65R15 Michelins on the RS and there still looked to be some room. I have a 9:30AM appointment tomorrow. Hopefully they won't have an issue putting the 195's on a 5.5" wheel. I know some places won't install much other than what's posted on the door jamb.
Old 08-24-2018, 12:14 PM   #24
06YarisRS
For you, sir.
My camera lens does not really convey the width of the tires. They do seem wider in person. I really wish they made this alloy in 16" and a tad wider. The installer did cause one very small ding in the clearcoat near the center cap, but I mixed up a couple drops of clear and filled it. I expect that if the clearcoat had been fully cured, that may not have happened. Will sand and buff out later. Absolutely no damage to the edges of the rims. Overall, a pretty good installation, IMO.
Old 08-24-2018, 06:02 PM   #25
kimona
kimona's Avatar
Very, very nice! You've put a lot of sweat equity into that little car and it shows.
Old 08-24-2018, 06:20 PM   #26
06YarisRS
Thanks Kimona! I love the little car. It looks great and is a blast to drive.
Testosterone: The New Synthetic Oil bronsin Off-topic / Other Cars / Everything else Discussions 23 12-15-2013 06:02 PM
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
